sic_fx Posted September 25, 2006 Report Share Posted September 25, 2006 can i run a colossus II at 1 ohm mono? i just sold all 4 of my stroker 15's, they are goin in an extended cab s-10. i would like to do the colossus II, it fits the budget for this guy better than a goliath does, and really wants hifonics power.any info would be more than greatly appreciated so i can get this guy some amp prices and get this install moving.thanks 2002 Tahoe Pioneer 4300dvdFront: Pioneer Components Rear: Kicker CVT6.5 sub amp: US Amps AX2000HC @.35 front stage amp: US Amps TU4360C(tube amps FTW!!)2-18" Level Crossfire XS-SPL V.1'sCheck Out My YouTube Videos!! Click This Now! Link to comment Share on other sites More sharing options...
Guest 90accordman Posted September 25, 2006 Report Share Posted September 25, 2006 indeed you can run it to 1 ohm http://www.maxxsonics.com/hifonics/amps_genxx.html bottom of page i was running a XXX off one Link to comment Share on other sites More sharing options...
sic_fx Posted September 25, 2006 Author Report Share Posted September 25, 2006 they rate it at 1 ohm stereo (2x1600 rms@ 1ohm) i need 1 ohm mono. the 4 strokers are single 4 ohms. but if it will run at 1 ohm mono that is the amp i'll run. 2002 Tahoe Pioneer 4300dvdFront: Pioneer Components Rear: Kicker CVT6.5 sub amp: US Amps AX2000HC @.35 front stage amp: US Amps TU4360C(tube amps FTW!!)2-18" Level Crossfire XS-SPL V.1'sCheck Out My YouTube Videos!! Click This Now! Link to comment Share on other sites More sharing options...
Guest 90accordman Posted September 27, 2006 Report Share Posted September 27, 2006 not with a colossus, the only way youll get the 3200 is bridging the 2x 1600s why not wire 2 to one channel at 2ohm and 2 to the other channel at 2ohm, youd get the same power as if you did it your way. Link to comment Share on other sites More sharing options...
sic_fx Posted September 28, 2006 Author Report Share Posted September 28, 2006 i think i found a digital diesigns z1 to use for this install. i told the guy i'm building this truck for about it and he seemed pretty stoked. now just to get him to give me the money to buy the bastard. i figure 4 15" strokers at 1 ohm on a z1 will get pretty fuc**ng loud. :^ :-* 2002 Tahoe Pioneer 4300dvdFront: Pioneer Components Rear: Kicker CVT6.5 sub amp: US Amps AX2000HC @.35 front stage amp: US Amps TU4360C(tube amps FTW!!)2-18" Level Crossfire XS-SPL V.1'sCheck Out My YouTube Videos!! Click This Now! Link to comment Share on other sites More sharing options...
Guest 90accordman Posted September 28, 2006 Report Share Posted September 28, 2006 your only giving them 8-9 hundred each ? Link to comment Share on other sites More sharing options...
sic_fx Posted September 28, 2006 Author Report Share Posted September 28, 2006 Bench tested by Peter.T from Soundpressure.com (Sweden): 12 Volts: 4.6 ohms = 2279W 2.3 ohms = 3405W 1.15 ohms = 4188W 14,4 Volts: 4.6 ohms = 3042W 2.3 ohms = 4461W 1.15 ohms = 5358W got that from ampguts, if it does 4100 at 12 volts i'll be happy. this guy wants to spend less than $1000 on an amp, and i can get him this amp for that price. it'll be nuts any way you look at it...4-stroker 15's, 4kw, ext. cab s-10, 18.5 cu.ft, tuned to 31hz. this truck will be loud. p.s.-love the avatar :-*, that's a bad bit**. 2002 Tahoe Pioneer 4300dvdFront: Pioneer Components Rear: Kicker CVT6.5 sub amp: US Amps AX2000HC @.35 front stage amp: US Amps TU4360C(tube amps FTW!!)2-18" Level Crossfire XS-SPL V.1'sCheck Out My YouTube Videos!! Click This Now! Link to comment Share on other sites More sharing options...
AP Zoutes Posted September 29, 2006 Report Share Posted September 29, 2006 you can get a DD Z1 for under 1,000??? Link to comment Share on other sites More sharing options...
Guest 90accordman Posted September 29, 2006 Report Share Posted September 29, 2006 Bench tested by Peter.T from Soundpressure.com (Sweden): 12 Volts: 4.6 ohms = 2279W 2.3 ohms = 3405W 1.15 ohms = 4188W 14,4 Volts: 4.6 ohms = 3042W 2.3 ohms = 4461W 1.15 ohms = 5358W got that from ampguts, if it does 4100 at 12 volts i'll be happy. this guy wants to spend less than $1000 on an amp, and i can get him this amp for that price. it'll be nuts any way you look at it...4-stroker 15's, 4kw, ext. cab s-10, 18.5 cu.ft, tuned to 31hz. this truck will be loud. p.s.-love the avatar :-*, that's a bad bit**. GL with the cu feet your trying to get, i believe manny has 8 cubes in his and it looks like there isnt much more room Link to comment Share on other sites More sharing options...
