need a box design for a Single sealed 12 HT box
hello SMD im in need of a design.
i want to do a single 12 in a sealed box. its going to be for a home theater project. Its gonna fit a single 12 infinity kappa perfect and a dayton 240 watt amp. Sub needs about 1 cube and the amp displacement is 8.5 x 8.5 x ???
not sure on the depth, parts express says its 5 inches deep, but not sure if that is the whole item (heat sink fins and all) here is the one im looking at : http://www.parts-express.com/pe/showdetl.cfm?Partnumber=300-804
i would like to do a down fire with the plate amp on the back.
thanks.
Edited by Gavinvoy
I have that amp, and it just doesn't put out the power you want sealed
in a ported box, you may get better output, but even free air you will only get about 1/4" of excursion if that.
I got lucky with that amp and a 18" I made that just had super soft suspension.
But bottom line, that set up, I would do ported, and tune it low
do you have the grounding issue with the amp?
ill keep that in mind.
fixed link.
Edited by Gavinvoy
  • Who's Online   1 Member, 0 Anonymous, 830 Guests (See full list)
