MAybe a maxxlink?
I would like to thank every 1 for the input i splice the wires together and boy what a difference it was hard with 2 bass knobs to get that equal sound. Hope all goes well next sunday. Now all i have to do is get my mids and highs together.
Glad to read this, good look with your new mids/highs :yahoo:
Im not 100% sure but if u have say 2 D2 subs and u wire both to 1ohm for each amp if they can handle it and hook 1 amp apeice to each sub and link them together it would still be a 1ohm load. some one correct me if i'm wrong cause ive kinda wondered this as well. but first u gotta make sure the amps are even linkable.
If your strapping the amps you generally have to provide a 2ohm load which you would need D2's for (with 1ohm it would result in a .5ohm final as the amps halve it). 1ohm amps need 2ohm for strap, .5ohm amps need 1ohm, etc... You then take positive sub to positive master and then negative sub to positive slave (that is generally how it works, but not always).
Edited by UnderLoK
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
2 270a Mechman Alts
  • Who's Online   2 Members, 0 Anonymous, 1094 Guests (See full list)
