LoudNLow931 Posted June 6, 2010 Report Share Posted June 6, 2010 And if you do buy that from darvex, use "Meade" for 5% off. Quote 2008 Dodge Ram 2500 6.7l Cummins 4 FT1s C1600.2 8 PWX 8s ONX2.100 Audio Technix Wiring & Sound Deadener My Youtube Feedback Link to comment Share on other sites More sharing options...
fecupe2001 Posted June 6, 2010 Report Share Posted June 6, 2010 MAybe a maxxlink? Quote I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/ Link to comment Share on other sites More sharing options...
Xtace Posted June 6, 2010 Author Report Share Posted June 6, 2010 I would like to thank every 1 for the input i splice the wires together and boy what a difference it was hard with 2 bass knobs to get that equal sound. Hope all goes well next sunday. Now all i have to do is get my mids and highs together. Quote Link to comment Share on other sites More sharing options...
fecupe2001 Posted June 6, 2010 Report Share Posted June 6, 2010 Glad to read this, good look with your new mids/highs Quote I´m the SPL Gains topic creator!! wanna get louder?? check this: SPL Gains. Panamenian 2009 & 2010 & 2014 Bass Race 149.9 Champion! 2 15" subs and a 2K wired at 1 ohm, http://www.stevemeadedesigns.com/board/topic/167788-fecupe2001-2-15s-on-a-2k-video-on-page-3/ 8 Massive 15" subs and small power, http://www.stevemeadedesigns.com/board/topic/179296-fecupe2001s-8-15s-4th-order-bandpass-wall/ Link to comment Share on other sites More sharing options...
Xtace Posted June 6, 2010 Author Report Share Posted June 6, 2010 Thanks Quote Link to comment Share on other sites More sharing options...
UnderLoK Posted June 6, 2010 Report Share Posted June 6, 2010 (edited) Im not 100% sure but if u have say 2 D2 subs and u wire both to 1ohm for each amp if they can handle it and hook 1 amp apeice to each sub and link them together it would still be a 1ohm load. some one correct me if i'm wrong cause ive kinda wondered this as well. but first u gotta make sure the amps are even linkable. If your strapping the amps you generally have to provide a 2ohm load which you would need D2's for (with 1ohm it would result in a .5ohm final as the amps halve it). 1ohm amps need 2ohm for strap, .5ohm amps need 1ohm, etc... You then take positive sub to positive master and then negative sub to positive slave (that is generally how it works, but not always). Edited June 6, 2010 by UnderLoK Quote If at first you do not succeed, you are doing it wrong! -ARSCheck out my walled TBSS build over here4 Fi Team 18s on 2 Cactus K9 DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500 Pioneer X8500 6 XS Power D7500, 1 3400S Second Skin 2 270a Mechman Alts Link to comment Share on other sites More sharing options...
