Uploaded with ImageShack.us
Brand New US Amps VLX3DE 2400w RMS Class DE Mono Amplifier with High Speed Digital Power Supply
RMS Power at 4 ohms (12V): 600w x 1
RMS Power at 4 ohms (14v): 650w x 1
RMS Power at 2 ohms: 1200w x 1
RMS Power at 1 ohm (12v): 2000w x 1
RMS Power at 1 ohm (14V): 2400w x 1
Fuse Rating: 40A x 6
High-current Matched MOSFET devices
Independent front and rear gain adjustments
Field Replacable "HSDPA" circuitry full range drive module
Field replaceable "PWM" power supply control module
Magnetic Induction Regulated Drive Power Supply
Drive pulse regulation down to 9 volts input (1DE/2DE/3DE)
35 nanosecond Switching Diodes
All metallized, high temperature, low ESR capacitors
504 amps(1DE) / 1008 amps(2DE) / 2016 amps(3DE) of power devices
High capacity power transformer
Multiple Bypass capacitors on incoming 12 volt supply
Time delay turn on
Pulse-width Modulation power supply (2DE/3DE)
Thermal, current, and reverse polarity protection
New stability filter design for reduction in noise
Class DE technology utilizing our Elevated Efficiency Platform (1DE/2DE/3DE)
Output stages utilize high-current Matched MOSFET devices
High speed, audio-grade components in all low level stages
Platinum plated RCA inputs and connectors
Wide range of sensitivity accepts signal from any head unit including speaker leads
24 dB/octave Subsonic Filter (1DE/2DE/3DE) / 24 dB/octave Electronic Crossover
True line output / Auto bridge feature / Short circuit protection
Balanced Tranformerless Logic input for the highest possible Damping Factor,Slew Rate and Signal-to-Noise Ratio
390 amps(1DE) / 684 amps(2DE) / 912 amps(3DE) of output devices
Double 30-amp speaker relays (2DE/3DE)
90% High Density Construction Surface Mount Technology
Use 0 gauge power and ground wire for installation
Use minimum 12 gauge speaker wire for installation
Use minimum 16 gauge remote wire for installation
THD: 0.09 %
S/N Ratio: 80 dB
Frequency Response: 20 HZ - 250 HZ
Crossover Frequencies: Low-Pass - 40 - 250 HZ
Subsonic Filter: 15 HZ - 40 HZ
Input Sensitivity: 350 mV / 9.0 V
Damping Factor: > 200
Dimensions in inches: 16.5" L x 9.75" W x 2.25" H
Power Voltage Range: 10V-16V
98 Chevy Blazer 4 Door
Stock Everything
The New Setup
1 - Pioneer AVH-P5200DVD
1- Pioneer DEH-80PRS
2 - Blues Audio 5.25 Mids ( On the dash )
2 - Blues Audio BL8.0C Components ( In the front doors )
2 - Blues Audio BL8.0 Woofers ( In the rear doors )
1 - Linear Power 952 ( Dash )
1 - Linear Power 2202IQ Modified ( Components )
1 - Linear Power 3002 ( Rear Doors )
1 - SoundStream XBP-10 Processor
1 - SoundStream BX-20Z
2 - SoundStream DTR1.3400D
4 - RE Audio SX12D4
Share this post
Link to post
Im in LOVE
Stock Everything
The New Setup
4 - RE Audio SX12D4
Share this post
Link to post
Who has this amp?
Stock Everything
The New Setup
4 - RE Audio SX12D4
Share this post
Link to post
looks like MD3's got a little reworking.
other then the name and class "de" what really differentiates this from the md series
Share this post
Link to post
Look between the big caps. Those 2 black chips are new.
Stock Everything
The New Setup
4 - RE Audio SX12D4
Share this post
Link to post
The MD3D are nice and have lots of power. I had 2 and they were powerful. I have 2 Soundstream DTR1.3400d D-Towers. They are power houses. But this is making me think about selling the D-Towers.
Stock Everything
The New Setup
4 - RE Audio SX12D4
Share this post
Link to post
I really want this.
Stock Everything
The New Setup
4 - RE Audio SX12D4
Share this post
Link to post
I want that.
Stock Everything
The New Setup
4 - RE Audio SX12D4
Share this post
Link to post
Post me a picture.
Stock Everything
The New Setup
4 - RE Audio SX12D4
Share this post
Link to post
