hzsogood Posted August 27, 2010 Report Share Posted August 27, 2010 (edited) Could I get a quote from you for a 96 pontiac grand am gt, 3.1 v6 Didnt see any threads about it already, or anything on your site.. Thanks! Edited August 27, 2010 by comatoastedlush Quote Link to comment Share on other sites More sharing options...
MECHMAN Posted August 30, 2010 Report Share Posted August 30, 2010 That vehicle uses a small CS130 unit. We only build large case units, because small case HO alternators do not have enough cooling or low RPM output. We have a late model large housing conversion kit for $449. It puts a large 220 amp unit in place of your CS130. Because we use the larger housing, our unit has great output at idle, and bomb-proof durability for daily use. We machine the housing and include a clearance bracket so that is has the same bolt pattern as your OEM unit. On your particular vehicle, it requires you to grind the OEM alternator bracket for clearance. Our complete kit is $449 shipped. Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
hzsogood Posted September 1, 2010 Author Report Share Posted September 1, 2010 That vehicle uses a small CS130 unit. We only build large case units, because small case HO alternators do not have enough cooling or low RPM output. We have a late model large housing conversion kit for $449. It puts a large 220 amp unit in place of your CS130. Because we use the larger housing, our unit has great output at idle, and bomb-proof durability for daily use. We machine the housing and include a clearance bracket so that is has the same bolt pattern as your OEM unit. On your particular vehicle, it requires you to grind the OEM alternator bracket for clearance. Our complete kit is $449 shipped. Gotcha man, TY.. Im trying to decide If Im gonna do a full blown setup in this car or not.. If NOT, Would the stock electrical, one run of 1/0 run back and a 3100 be fine for a true 3K rms? Quote Link to comment Share on other sites More sharing options...
MECHMAN Posted September 2, 2010 Report Share Posted September 2, 2010 Gotcha man, TY.. Im trying to decide If Im gonna do a full blown setup in this car or not.. If NOT, Would the stock electrical, one run of 1/0 run back and a 3100 be fine for a true 3K rms? That would be OK. One of our adjustable voltage 150 amp units would help out quite a bit over the stock alternator, we could build one in the OEM housing for around $250 and it would still be durable and have good idle output. Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
corteznewbie Posted September 2, 2010 Report Share Posted September 2, 2010 wut bout us jeep guys that have our voltage contraled by the ecu?? Quote Team DBs (Driven By sound) Link to comment Share on other sites More sharing options...
MECHMAN Posted September 2, 2010 Report Share Posted September 2, 2010 Our custom machined units actually utilize their own internal regulator, and send out a dummy signal to the Jeep regulator so that the alternator light doesn't come on. This way we have a standard 14.7 volt colt regulator setpoint. Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
corteznewbie Posted September 2, 2010 Report Share Posted September 2, 2010 sweet sweet i'm stuck at 13.8 trien to get 14. 6 or so Quote Team DBs (Driven By sound) Link to comment Share on other sites More sharing options...
MECHMAN Posted September 2, 2010 Report Share Posted September 2, 2010 If you don't mind having the alternator light come on in the dash, we can set you up with on-the-fly voltage adjustment as well... Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
corteznewbie Posted September 2, 2010 Report Share Posted September 2, 2010 price of it ? Quote Team DBs (Driven By sound) Link to comment Share on other sites More sharing options...
MECHMAN Posted September 2, 2010 Report Share Posted September 2, 2010 What is the make/model/year/engine of your jeep? Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
