Mechman Alternators
alt for 97 chevy lumina
im looking for the biggest alt you got for a 1997 chevy lumina 3.1 L
R.I.P!
(Nov-29-2009)
92 explorer
current build
Your vehicle uses a CS130D small housing alternator , that really isn't capable of more than 200 amps, with crappy output at idle.
Our unit for that vehicle is a Custom machined large case housing that bolts directly in place of your small case unit. Our unit does 270 amps, with 165 amps at idle, with rock-solid durability for daily use. It is a direct bolt in, direct plug in, and comes with our solid copper competition rectifier assembly standard. The complete bolt in swap kit is $499 shipped.
this unit is for a slightly different GM application, but you get the idea in size comparison. Notice the difference in the rectifier size, that's why our unit can run fine at 270 amps, whereas the stock unit will burn up quick:
that sounds good mechman i'll be ordering that around october.... will the Vcm work with the lumina/alt
R.I.P!
(Nov-29-2009)
92 explorer
current build
nice and the price on that is
R.I.P!
(Nov-29-2009)
92 explorer
current build
  • Who's Online   0 Members, 0 Anonymous, 1135 Guests (See full list)
