albert23 Posted September 18, 2010 Report Share Posted September 18, 2010 so i got a 01 blazer xtreme with 2 custom lvl 5 15s and i want to see how people on here kept the rear hatch from rattling? Quote Link to comment Share on other sites More sharing options...
smokeumtires Posted September 18, 2010 Report Share Posted September 18, 2010 HAHA good luck Check out Nofearx18....... He owns a blazer with a shitton of deadening and it STILL rattles and wears down his back latch Quote Link to comment Share on other sites More sharing options...
albert23 Posted September 18, 2010 Author Report Share Posted September 18, 2010 yea i know i have like 4 layers of it through my whole car lol Quote Link to comment Share on other sites More sharing options...
cubs_fan0718 Posted September 18, 2010 Report Share Posted September 18, 2010 (edited) I had a 00 zr2 Blazer and the hatch would rattle constantly, i got rid of it before i could try a small trick i heard about, try wrapping the part the latch hooks onto in electrical tape that will help some supposedly, but i also heard you have to re-wrap it every so often cause it starts to eat at the tape. EDIT: unless you do a wall (i think) you are gonna have hatch rattle. Edited September 18, 2010 by cubs_fan0718 Quote 06 Impala SSKenwood Excelon DDX593 Ampere Audio 150.4 Ampere Audio 5K1 XS D4700 (front)Mechman 320a Alt. w/ Big 3 Lots of Second Skin Damplifier Under Construction for 2017 Link to comment Share on other sites More sharing options...
albert23 Posted September 18, 2010 Author Report Share Posted September 18, 2010 ok cool ill have to try that..ill let you know if it works Quote Link to comment Share on other sites More sharing options...
98crewcab Posted September 18, 2010 Report Share Posted September 18, 2010 are there multiple rods running together? once I put the 8's in my doors, they rattled like crap, took the panels back off, wrapped them with gorilla tape, then zip tied them together. just tight enough to keep pressure on the links, while still allowing them to slide....hope it helps.......... Quote 06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck) 7" BDS HC lift kit (5) 37x13.5R18 Toyo Open Country M/Ts (5) 18x10 Moto Metal MO962 tablet in lieu of deck blue tooth interconnect to soundstream eq (for volume control and bass control) 4 Alpine type r 10's 6 cubes net, 80sqin's port, tuned to 33hz 2 brutus brx5000.5's 2 pairs 3" polk audio for a pillars 4 pairs polk audio 6.5 comps 1 pair 8" polk audio for mids 2 xspower d3400 batteries.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!P.S. Thanks Steve....for the demo!!!! loud as fauk! Link to comment Share on other sites More sharing options...
albert23 Posted September 18, 2010 Author Report Share Posted September 18, 2010 are there multiple rods running together? once I put the 8's in my doors, they rattled like crap, took the panels back off, wrapped them with gorilla tape, then zip tied them together. just tight enough to keep pressure on the links, while still allowing them to slide....hope it helps.......... thanks man im going to have to try that to Quote Link to comment Share on other sites More sharing options...
albert23 Posted September 19, 2010 Author Report Share Posted September 19, 2010 I had a 00 zr2 Blazer and the hatch would rattle constantly, i got rid of it before i could try a small trick i heard about, try wrapping the part the latch hooks onto in electrical tape that will help some supposedly, but i also heard you have to re-wrap it every so often cause it starts to eat at the tape. EDIT: unless you do a wall (i think) you are gonna have hatch rattle. hey thanks man the tape thing work pretty good but you do have to re-wrap it a lot cause it kills the tape but it does help a lot thanks Quote Link to comment Share on other sites More sharing options...
BeatBox Posted September 19, 2010 Report Share Posted September 19, 2010 I had a 00 zr2 Blazer and the hatch would rattle constantly, i got rid of it before i could try a small trick i heard about, try wrapping the part the latch hooks onto in electrical tape that will help some supposedly, but i also heard you have to re-wrap it every so often cause it starts to eat at the tape. EDIT: unless you do a wall (i think) you are gonna have hatch rattle. good trick used it on mine. i also heard, but never tried....you can put washers in between where the latch piece bolts down to the tailgate, to bring in the glass a little tighter when you close it another small trick is putting foam/tape on the glass touches the weather stripping. its the tape with one side sticky and has a small layer of foam on the other side. (used for sealing house doors from the cold) Quote Link to comment Share on other sites More sharing options...
albert23 Posted September 19, 2010 Author Report Share Posted September 19, 2010 good trick used it on mine. i also heard, but never tried....you can put washers in between where the latch piece bolts down to the tailgate, to bring in the glass a little tighter when you close it another small trick is putting foam/tape on the glass touches the weather stripping. its the tape with one side sticky and has a small layer of foam on the other side. (used for sealing house doors from the cold) yea i tryed the one with foam but didnt relly help ill have to try the one useing the washers thanks man Quote Link to comment Share on other sites More sharing options...
