jdl01gt Posted November 11, 2010 Report Share Posted November 11, 2010 i was wondering what alt you offer for a 2007 dodge magnum with the 5.7L, and if it uses the same housing as the stock alternator Quote 07 Corolla S 2-p3 15's in a custom fiberglass box powered by a p1001bd, Fosgate punch series components that hit 140.1 on Term Lab 07 Magnum R/T 1-??? sub powered by RF 2500-1bd, Big 3, 2-shuriken bt-120 batteries. 99 Ford F-150 Reg Cab 2-10in Powerbass ps subs in a MTX Thunderform box Powered by ASA1000.1. Hit 132.4 on Term Lab Link to comment Share on other sites More sharing options...
MECHMAN Posted November 11, 2010 Report Share Posted November 11, 2010 We offer two direct fit units for that application: 270 amp ES Custom large case housing 165 amps by 700 rpm full output by 1800 rpm custom solid copper rectifier 8 70 amp diodes overdrive pulley Oversize charge posts $499 320 amp ER OEM housing with AC snake 165 amps by 700 rpm full output by 1800 rpm Custom fan cooled remote rectifier 16 70 amp diodes Overdrive pulley Oversize charge posts $599 + core Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
jdl01gt Posted November 14, 2010 Author Report Share Posted November 14, 2010 what do you mean oem housing with AC Snake Quote 07 Corolla S 2-p3 15's in a custom fiberglass box powered by a p1001bd, Fosgate punch series components that hit 140.1 on Term Lab 07 Magnum R/T 1-??? sub powered by RF 2500-1bd, Big 3, 2-shuriken bt-120 batteries. 99 Ford F-150 Reg Cab 2-10in Powerbass ps subs in a MTX Thunderform box Powered by ASA1000.1. Hit 132.4 on Term Lab Link to comment Share on other sites More sharing options...
MECHMAN Posted November 15, 2010 Report Share Posted November 15, 2010 It means is has a fan cooled remote mounted rectifier, so that all of the heat is mounted away from the windings of the alternator. That is the only way to make that particular OEM housing durable at 320 amps worth of output. Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
jdl01gt Posted November 16, 2010 Author Report Share Posted November 16, 2010 so if i buy the 599 alt and send in mine it will use the same housing as my stock alt and will fit exactly the same as factory one Quote 07 Corolla S 2-p3 15's in a custom fiberglass box powered by a p1001bd, Fosgate punch series components that hit 140.1 on Term Lab 07 Magnum R/T 1-??? sub powered by RF 2500-1bd, Big 3, 2-shuriken bt-120 batteries. 99 Ford F-150 Reg Cab 2-10in Powerbass ps subs in a MTX Thunderform box Powered by ASA1000.1. Hit 132.4 on Term Lab Link to comment Share on other sites More sharing options...
MECHMAN Posted November 17, 2010 Report Share Posted November 17, 2010 (edited) That is correct, Even though our large case conversion kit is probably easier to install anyway. Edited November 17, 2010 by MECHMAN Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
