KnockinthaStreetzof608 Posted November 20, 2010 Author Report Share Posted November 20, 2010 email this guy Nightmare Audio will he/she give me a decent price on the box? Quote CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED! Link to comment Share on other sites More sharing options...
Kranny Posted November 20, 2010 Report Share Posted November 20, 2010 whats with the precise ass dimensions? just go by .25 jumps. Quote Link to comment Share on other sites More sharing options...
KnockinthaStreetzof608 Posted November 20, 2010 Author Report Share Posted November 20, 2010 (edited) whats with the precise ass dimensions? just go by .25 jumps. u right it would be easy well what do you guys think will be a good start 13height 26 length 18length i believe Edited November 20, 2010 by KnockinthaStreetzof608 Quote CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED! Link to comment Share on other sites More sharing options...
Kranny Posted November 20, 2010 Report Share Posted November 20, 2010 u right it would be easy well what do you guys think will be a good start 13height 26 length 18length i believe why is your width 28.9? just make it 29. same with port height and width, why not just make it 3.0 or 2.75. by the way you have absolutely no port area. look at the port area and port area range. see something wrong? Quote Link to comment Share on other sites More sharing options...
TeamHT Posted November 20, 2010 Report Share Posted November 20, 2010 will he/she give me a decent price on the box? I've used him when I get too busy and have multiple enclosures to build. Great stuff and I think he charged like $5 or $10 per design. Good guy and great designs. My current build walling off my silverado was designed by him. Quote Tell me...does this smell like chloroform to you? Link to comment Share on other sites More sharing options...
KnockinthaStreetzof608 Posted November 20, 2010 Author Report Share Posted November 20, 2010 (edited) better??? Edited November 20, 2010 by KnockinthaStreetzof608 Quote CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED! Link to comment Share on other sites More sharing options...
Kranny Posted November 20, 2010 Report Share Posted November 20, 2010 you have managed to get even less port area...look at what i said. PORT AREA RANGE and PORT AREA. the 2 numbers on the bottom right side. put 2 and 2 together and make your ports bigger. Quote Link to comment Share on other sites More sharing options...
KnockinthaStreetzof608 Posted November 20, 2010 Author Report Share Posted November 20, 2010 you have managed to get even less port area...look at what i said. PORT AREA RANGE and PORT AREA. the 2 numbers on the bottom right side. put 2 and 2 together and make your ports bigger. how much much bigger do you think i should make my ports??? Quote CAR -2005 Ford Mustang (Legand Lime) H/U -Pioneer avh 3200dvd Amps 2 AQ 3500d.1s strapped 1ohm daily .25burps 1Sundown Audio 100.4 1 Sundown Audio 125.2 Subs 4 AQ HDC'4s 12's Mids and highs 4 Sundown Neo Pro 8s 2 AQ Super Tweeters Electronical Mechman 270 unit 1 D3400 2 D3100's WALLED! Link to comment Share on other sites More sharing options...
Kranny Posted November 20, 2010 Report Share Posted November 20, 2010 how much much bigger do you think i should make my ports??? i dont know, put 11.75 for height (keep it that way) and play with the width and length till you get a number for Port Area thats between the two numbers in the Port Area Range. simple as that. oh and btw put 3 for the # of common port walls Quote Link to comment Share on other sites More sharing options...
Clif Posted November 20, 2010 Report Share Posted November 20, 2010 I would go back to where you got the calculator and reread the post on how it works and what to do. After that read it 5 more times and you will understand it. Then come back if you still have questions. And read the whole thread not just the first post. my 2 cents..... Quote 03 Trailblazer EXT LT In Dash Rear Flip Down Polk Audio Font & Rear Stage Hifonics Zeus 4 Chan Amp Hifonics Brutus Mono Amp 12" Rockford Fosgate Power HX2 T-Line tuned to 45hz 18"BTL T-line @31Hz (9 weeks pregnant) Link to comment Share on other sites More sharing options...
