mazdaspl Posted December 7, 2010 Report Share Posted December 7, 2010 Im looking on getting a new alt for my truck that is a direct bolt on application.. Im leaving it up to you what you recommend...Also was not sure what belt i will be needing.. Thanx Jay Quote Link to comment Share on other sites More sharing options...
MECHMAN Posted December 10, 2010 Report Share Posted December 10, 2010 We offer a few models for you truck. They are all a direct bolt in, Large case conversion kit designed specifically for your vehicle. They include a custom machined large housing alternator, adaper bracket, and plug-n-play harness. Your truck is mainly limited by the belt that it uses. Anything beyond about 200 amps worth of load, and it will want to slip the belt, just FYI. 220 amp (135 idle) = $499 270 amp (165 idle) = $549 320 amp (100 idle) = $599 We can add the adjustbale voltage module to any of the above units for only $50 additional. All of the above units come standard with our custom rectifier and oversize diodes and terminals for bomb-proof durability. They are all dyno tested and warranted for a year. Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
