CaptainzPlanetz Posted December 28, 2010 Report Share Posted December 28, 2010 I got a quote around the time I first joined but I figured prices have changes since then....... I need a quote on the models you offer for 200-270amp alts. 2003 Pontiac Grand Am 3.4 6 Cylinder Engine AC Delco factory alt Thanks Quote ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members. Link to comment Share on other sites More sharing options...
MECHMAN Posted December 28, 2010 Report Share Posted December 28, 2010 We have a 270 amp unit that is a direct bolt in, large case replacement for $449. It has a slightly larger stator and rotor, and makes 165 amps at idle, full output by 1800 rpm. It comes standard with our top of the line custom solid copper rectifier, oversize terminals and diodes, overdrive pulley, and one year warranty. We can also add the adjustable voltage boost module option to it for only $50 additional. (Reg. $99) regards Matthew Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
