GioRF Posted January 24, 2011 Report Share Posted January 24, 2011 (edited) Whats the most amps alt that you(MECHMAN) have for a 4AFE engine. Direct bolt on. For a 1991 COROLLA 4DR. Edited January 24, 2011 by GioRF Quote Link to comment Share on other sites More sharing options...
MECHMAN Posted January 25, 2011 Report Share Posted January 25, 2011 240 amp large case conversion kit 135 amps by 700 rpm Full output by 1800 rpm Oversize rectifier oversize terminals overdrive pulley Adjustable voltage boost module included STANDARD Our unit is the physically largest unit that will fit, and will have much better low RPM output and durability than anything based on the OEM housing. $549 Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
GioRF Posted January 25, 2011 Author Report Share Posted January 25, 2011 How much shipped to PuertoRico at 00744? Quote Link to comment Share on other sites More sharing options...
MECHMAN Posted January 25, 2011 Report Share Posted January 25, 2011 We can normally ship USPS to Puerto Rico for $45 Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
GioRF Posted January 27, 2011 Author Report Share Posted January 27, 2011 Thanks for your fast response. I want to know if there is any modification involved in that conversion like plugs, adapters or anything that i need to change. Thanks. Quote Link to comment Share on other sites More sharing options...
MECHMAN Posted January 30, 2011 Report Share Posted January 30, 2011 Assuming that it is the same as a standard mainland US spec vehicle, there are no modifications necessary. It accepts the stock alternator plug, and bolts into the stock bracket. You will need to buy a slightly longer belt from the autoparts store however. Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
GioRF Posted February 1, 2011 Author Report Share Posted February 1, 2011 Is it the highest output alt that can fit or theres an stronger one? Quote Link to comment Share on other sites More sharing options...
GioRF Posted February 4, 2011 Author Report Share Posted February 4, 2011 Waiting on response. Thanks. Quote Link to comment Share on other sites More sharing options...
