eduardo817 Posted January 28, 2011 Report Share Posted January 28, 2011 needed something above 200 amps. somewere around 230 or 240 would be nice. income tax check came in and now im in need of a new alt Quote Link to comment Share on other sites More sharing options...
MECHMAN Posted January 30, 2011 Report Share Posted January 30, 2011 We offer a direct fit 270 amp Extreme Service unit for $449. It does 270 amps, 165 amps by 700 rpm, fulloutput by 1800 rpm It comes standard with our custom solid copper rectifier assymbly and 70 amp diodes for bomb proof durability. It also comes with an overdrive pulley installed on it, and oversize charge terminals with properly sized heavy duty alternator cable ends for your big 3 upgrade. It is dyno tested and gauranteed for a year. We can also add the adjustable voltage boost module for only $50 additional so you can set the charging voltage to whatever you want. regards matthew 865-522-6166 www.mechman.com Quote 1-888-MECHMAN www.Mechman.com [email protected] Link to comment Share on other sites More sharing options...
