Sound Deadner Where To Get It And Where To Get It Cheap
Its the same thing sept the top one I got from doug instead of foil it has thick fabric it seems to do really well. Ive got flowmasters dumping out under the cab and I can barely hear them. The bottom stuff is another form of peel and seal its more splash guard sealer its rubber and sticks super good but your gonna need 3 layers to = 1 layer of dynamat I ended up putting 2 more layers of the fabrick stuff over the top of it.
so what is it called and does it getting rid of noice and where can u get it and how much
new toy
97 chevy s10 ext cab
bagged
22s
system (coming soon )
4 soundstream t4-15s walled
2 concept 2410 mono amps
REFS
http://www.stevemeadedesigns.com/board/ind...hl=cartunez2004
http://caraudio.com/forum/showthread.php?t...ht=LOUDCARTUNEZ
Guest MegaloManiac
you want to have a foil backing. heres a good explanation
"There are a few reasons. Vibration dampers work best when you have a
viscoelastic material (the butyl adhesive) between to fairly rigid
layers. One is the sheet metal of the car. Aluminum foil provides the
other. When the panel and adhesive are moved by sound energy, tension
between the adhesive and both surfaces converts the movement to heat.
Two surfaces work better than one - the concept is called constrained
layer viscoelastic damping (CLVED). Google those terms and you'll get
as
much information as you can possibly use.
In addition to working as a vibration damper, sound deadeners also work
as barriers to actually block sound. Barriers work best when the sound
has to move through layers of very different densities. Mylar is to
close to the adhesive to do much good.
Final, butyl adhesive can burn. Covering it in aluminum foil makes it
self snuffing. Mylar also burns, so it can't provide that extra measure
of safety.
All of these points are publicly known and fairly easily discovered.
The
fact that some companies still choose to cheap out with Mylar tells me
they aren't a company I want to buy anything from :)"
  • Who's Online   1 Member, 0 Anonymous, 1420 Guests (See full list)
