gumedina83 Posted June 4, 2011 Report Share Posted June 4, 2011 hey guys, i got a question i have a jl audio 500/1 and today when i turned my system all the way down, i noticed it was still making a noise like a single tone and my stereo was all the way down i check all my wires moved some made sure they where tight not loose and it still has that tone playing through the subs.when i turn it up my subs sound good like normal what could it be. Quote Link to comment Share on other sites More sharing options...
srt8demon420 Posted June 4, 2011 Report Share Posted June 4, 2011 hey guys, i got a question i have a jl audio 500/1 and today when i turned my system all the way down, i noticed it was still making a noise like a single tone and my stereo was all the way down i check all my wires moved some made sure they where tight not loose and it still has that tone playing through the subs.when i turn it up my subs sound good like normal what could it be. bad ground maybe? check and see... Quote '91 geo Everest Sound Labs Kinetik Mechman Clarion if its too loud, your too old! Rob Link to comment Share on other sites More sharing options...
lowsound10 Posted June 4, 2011 Report Share Posted June 4, 2011 ^ that or you may have bad connections somewhere hidden that you didn't check or bad rcas Quote Vehicle: 2008 Mustang V6 Exterior: Blacked Out Taillights, Turn Signals, Side Markers-Black 18x8 Enkei ls5-6000k HID's Interior: Blue LED Strips with Module for Music-Hardwired Beltronics RX65 with Blue LED and remote button Sub: 2 10 inch custom subs Amp: Hifonics BRz 2600 Wire: Knu 0 gauge Headunit: Kenwood kiv-bt901 Damplifier: Fatmat Rattletrap Electrical: Stock Alt/Stock Battery/Big 3 Link to comment Share on other sites More sharing options...
srt8demon420 Posted June 4, 2011 Report Share Posted June 4, 2011 ^ that or you may have bad connections somewhere hidden that you didn't check or bad rcas true this^^^ Quote '91 geo Everest Sound Labs Kinetik Mechman Clarion if its too loud, your too old! Rob Link to comment Share on other sites More sharing options...
gumedina83 Posted June 4, 2011 Author Report Share Posted June 4, 2011 (edited) ok the noise its making is a rumble noise not a solid tone and the volume is all the way down i just turned the key i think its my amp. Edited June 4, 2011 by gumedina83 Quote Link to comment Share on other sites More sharing options...
srt8demon420 Posted June 4, 2011 Report Share Posted June 4, 2011 ok the noise its making is a rumble noise not a solid tone and the volume is all the way down i just turned the key sounds like rca to me.... or the rca terminals on the amp... Quote '91 geo Everest Sound Labs Kinetik Mechman Clarion if its too loud, your too old! Rob Link to comment Share on other sites More sharing options...
gumedina83 Posted June 4, 2011 Author Report Share Posted June 4, 2011 i just unplugged rca's and still the rumble i think i need to get my amp check. Quote Link to comment Share on other sites More sharing options...
srt8demon420 Posted June 4, 2011 Report Share Posted June 4, 2011 i just unplugged rca's and still the rumble i think i need to get my amp check. sounds like a plan Quote '91 geo Everest Sound Labs Kinetik Mechman Clarion if its too loud, your too old! Rob Link to comment Share on other sites More sharing options...
dcofer Posted June 4, 2011 Report Share Posted June 4, 2011 (edited) I had this same problem a while back with my pioneer deck, it could either be a bad ground on the amplifier or a bad ground on the deck itself, mine ended up being deck side so if you have the ability check that also, decks can be cheaper then amps if its faulty. Sounded like an engine rumble to me Edit, guess mine could have been a fault on the rca terminals on the deck, but def make sure all grounds are solid Edited June 4, 2011 by dcofer Quote Link to comment Share on other sites More sharing options...
gumedina83 Posted June 4, 2011 Author Report Share Posted June 4, 2011 ok i will ill check tomarrow Quote Link to comment Share on other sites More sharing options...
