Big 3 Alt Pictures N Questions
i go outside to do my big 3 and i look at my alt it has a harness and a small wire and screw making sure this is correct
Edited by ARMYSGT_D
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
1 optima yellow top (rear)
1 xs power 5100r (front)
big 3 and 1 run 1/0 stinger wire
my build
my rebuild
is that little bolt and wire where i will run from alt to battery
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
also looking at the bolt looks like theres barely any room to slip a terminal under is there another method i could useDSCF0964.jpg
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
Guest MegaloManiac
a spacer should help fit the terminal more flush and have a better connection. if you are skeptical that isnt the alty break out the dmm
yep thats a harness at the bottom, you dont need to mess with that.
Edited by MegaloManiac
i know thats the alty but just making sure thats the right place those are the only 2 outputs on the alty
what am i looking for with dmm ive never used 1 but my neighbor has 1 i can borrow
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
Guest MegaloManiac
well now that i think of it i dont know how much the dmm will help right now. cause i realize you have a new camry so you cant do what i was thinking without possibly hurting the car. DMM will just measure voltage for the situtation.
Run your battery Pos to Alt pos. Run it to that stud coming out of the alt.
Take that nut off, slide your 1/0 ring terminal or whatever your big 3 wire is onto the stud reinstall nut, tighten. Simple as that! Let me go take a picture of mine.
EDIT:
Edited by Audiobahnaholic
HU: JVC KD-AVX1Speakers: Stock BlazerSub: 2 Mass Destruction Car Audio Sidewinder 12"Amp: Orion HCCA-D1200 @ 1ohm (600 RMS)Box: 3.0 cubes tuned to 35
  • Who's Online   0 Members, 0 Anonymous, 432 Guests (See full list)
