ARMYKYLE1's Blazer Build, GFY it's slowwwww
No big updates. I have a tiny temp setup in. Little treo 12 on my T800.2 Not too bad for a cheap little 12.
Going to be picking up a dual 18 box from a friend soon. Throw my DP 18's in it, tuned to 29, then about 5-6k.
My 5 wide D3100 busbars are on order via project DB, great CS.
First official video. Put a little bit more power to the 12. Probably about 1200rms, on a sub rated for 400rms :) Definitely a gain, but not enough. I will say it's impressive for a baby 12.
  • 4 weeks later...
Inside one of the buildings
My GF and the Blazer looking around
One of the stages
DAEWOO FTMFW!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Got a new temp setup in. Probably only about 3k of real power. Subs barely move maybe an 1" peak to peak. Hopefully have more power for STC :)
Cleaned up my cluster fawk. Keep in mind this is a temporary setup. So I'm not cutting the wires to fit right now. Also the the project db is "backwards" since I had them setup for when I put the batteries to the back. Then it won't be backwards :) I need more amps so I can fill up the holes!
The before
The after
I'll rerun some more wire before scrapin to clean it up a little bit. But I don't to waste a lot on a temp gig. I'm also hoping to double power for it too.
I'm super happy with the busbars. Perfect bevel on the inlets, everything clean and smooth. This is my fourth purchase so far. Each one has been great. Also mechman and xs power ftw :) zero drop at idle!
Well I thought my window regulator broke or the track system, it randomly popped and the window fell :( Well I guess it was basshead problem. The three nuts holding the regulator on, fell off. Only managed to find two though :( But it's all back up and working. Also Did some work on the rear hatch to make it tighter. I basically spaced the latch off a little bit more. It helped. But not enough.
How it looked when I popped the cover off.
Taking the tailgate apart.
So, I've added more power, quite a bit more. Sound deadener, more bracing internally. Changing my front stage up a little for scrapin too. I've also added some air shocks.
Getting ready for surgery.
Broke a window track bolt trying to work on the doors.
More tweeters
Sealing up the windows. I'll clean the urethane up later.
9PM and still hot as fawk
Super amazing custom brackets.
Left the rear glass release solenoid release plug off when I put the tailgate back together. So I had to squeeze beside the box. Well I forgot a trim clip on the interior of the truck. I was in too deep before I realized.
A little blood lol.
The culprit
Making some new jumpers for the subs.
Tailgate
Ripped the roof brace glue crap.
The air shocks. They're rated from 25-200psi. Right now I'm sitting at 75ish. Almost perfect level and rides great. I had to pull some wire down but I'll button that up later.
New air shocks, old factory bilstiens. Still had some left in them too.
It's hard to tell, but I gained almost 3" in this pic. I'll do a proper before and after soon.
Couldn't think of another spot and I didn't feel like drilling.
  • Who's Online   1 Member, 0 Anonymous, 485 Guests (See full list)
