Alternator Issue
I have a dual set up on My Tahoe 2002 2wd 5.3 engine both 140 amps each. I just got back from an alternator shop an I was told that one of them wasn't charging at all. He said it can be recoiled to 150 amps.
I need some help to figure out if I should change them both to a higher output .maybe a dual 200x2 Stinger alternators or something else. The whole set up is Diamond Audio done about 3 years ago:
Exide battery at engine bay and 4 exides at the rear
4 1200 mono block amps
1 600 4ch
4 TDX 15" DVC diamond subs 1000 RMS / 2000 Max
1 3way component set Hex series Front stage
1 6.5" component set Hex series Rear stage
1 5 1/4 coaxial for rear fill
I purchased this truck with all the system in it. Any Ideas how to figure out the proper amps on a dual set up or simply change the bad one.By the way I was told that the non working alt is the one charging the rear batteries. Thanks !
  • Who's Online   1 Member, 0 Anonymous, 1333 Guests (See full list)
