Rockford Fosgate Punch Power 50.1
fosgatefan821
I got this today off craigslist
2007 Ford Ranger
(ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES)
K&N Performance Air Intake
Massive Audio D2400 Mono Amplifier
2 Custom Built 8" Subwoofers in Ported Enclosure
Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed)
4 - Pioneer TS-A6886R 6" X 8"
2 - SMD Heavy Duty Single ANL Fuse Blocks
2- Stinger SPP1200 Dry Cell Batteries
JL AUDIO Interconnects
2/0 Gauge Big 3
ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals
ILL Customz 1/0 to 4 Gauge Power / Ground Reducers
Factory Alternator
__________________________________________________________________________________________________________________________________
2002 Cheverlot Monte Carlo SS - (Deceased)
2 - Rockford Fosgate Power 1501BD
1 - Rockford Fosgate Power 851x
Rockford Fosgate Power 6 1/2 Components
Rockford Fosgate Power 3 way 6x9
2 - JL Audio W7 13.5" Subwoofers (Sealed)
Pioneer AVH-P4400BH In - Dash DVD Player
Pioneer AVIC - U250 - Add-on GPS Navigation System
Audio Control 6XS 4 Way Crossover / Line Driver
Ohio Generator 200 Amp Alternator
3 - Stinger SPP1200 Batteries
1 - Optima D34/78 Battery
2007 Ford Ranger
2/0 Gauge Big 3
Factory Alternator
Dynamic Power Rating (IHF-202 Standard) - Measured at 14.4V
Mono into a 4W load 100 Watts
Mono into a 2W load 200 Watts
Mono into a 1W load 325 Watts
2-channel Bridged (using 2 Punch 50.1) into a 2W load 650 Watts
Continuous Power Rating (Competition Standard) – Measured at 13.8 Volts
RMS continuous power mono, into a 4W load from 20-20,000Hz
with less than 0.05% THD 50 Watts
RMS continuous power mono, into a 2W load from 20-20,000Hz
with less than 0.10% THD 100 Watts
RMS continuous power mono, into a 1W load from 20-20,000Hz
with less than 0.3% THD 200 Watts
RMS continuous power bridged, (using 2 Punch 50.1
Power amplifiers in the same system) into a 2W load
from 20-20,000Hz with less than 0.3% THD 400 Watts
Signal-to-Noise Ratio: >100dB (A-weighted)
Frequency Response: 20Hz-20,000Hz ±0.5dB
Bandwidth: 10Hz–250kHz ±3dB
Damping Factor @ 4W (at output connector): >200
Slew Rate: 50V ms
IM Distortion (IHF): <0.05%
Input Impedance: 20k Ohms
Source Unit Compatiblity (+15dB gain overlap): 28V max. input
Input Sensitivity (+0dB gain overlap): Variable from 300mV to 5V
Pass-Thru Output: Unity Gain
B+ Fuse Size: (External to amplifier) 40 Amp or two 20 Amp
Fuse Type: AGU
Crossover Slope: 12dB or 24dB/octave Butterworth
Factory Crossover Frequency: 80Hz (0.047mf)
Factory Default Crossover Setting: Full Range
Dimensions: 9-5/8"W x 13-9/32"L x 2-5/8"H
(24.4cm) x (33.73cm) x (6.6cm)
2007 Ford Ranger
2/0 Gauge Big 3
Factory Alternator
  • Who's Online   0 Members, 0 Anonymous, 1647 Guests (See full list)
