FIRLAND AUDIO XL3KD GUTS...???
louVega
For those interested I was sent spec sheet from Zenon Audio for XL3KD.
Digital Class-D linkable mono block amplifier Dual MOS-FET PWM power supplies Daisy-chain through output Jack Double sided through hole epoxy PCB Stable into 1 ohm and 2 ohm parallel amplifier connection 24dB/oct variable crossover Variable 24 dB low pass (LPF) crossover Variable Bass Boost Variable phase shift Variable subsonic filter
Efficiency : 86% @ 4 ohm, at 100Hz Multi-way protection circuitry (thermal/over current/speaker short/speaker DC protection) RCA line input
Heavy duty copper layer double sided epoxy PCB Zero(0) gauge power supply connectors
Tested voltage & THD : 14.4V & less than 1% THD Operating voltage : DC10V~16V Wired remote control
Rated power output @14.4v
1020wx1 4 ohms
1900wx1 2 ohms
3050wx1 1 ohm
3600wx1 4 ohms strapped
5500wx1 2 ohms strapped
Signal to noise ratio -------------> 90db
Low pass freqency crossover 30hz-250hz subsonic filter---------- 10Hz~30Hz
Bass boost @ 45hz------- 0~12dB
Bass boost Frequency----30hz-90hz
Phase shift control ------0-180 deg Frequency response-10hz-350hz (+/-1db) THD@RMS watts <1.0%
Efficiency @ 4 ohm 86%
300A (external type fuse)
200mV ~ 6V (+/- 5%)
250(W) x 58(H) x 520(L)
  • Who's Online   0 Members, 0 Anonymous, 928 Guests (See full list)
