Desousa93 Posted January 28, 2014 Report Share Posted January 28, 2014 would 40 lbs of this be able to do 4 doors a roof and a trunk of a 99 Infiniti i30 ( 99 maxima) http://store.secondskinaudio.com/b-stock-40-pounder/ Quote New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky. Link to comment Share on other sites More sharing options...
Desousa93 Posted January 29, 2014 Author Report Share Posted January 29, 2014 44 views and nobody ? Quote New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky. Link to comment Share on other sites More sharing options...
Desousa93 Posted January 29, 2014 Author Report Share Posted January 29, 2014 the 80sq ft pack only weighs 32pounds so you should be able to do the whole car 80 sq feet would to the whole car? i wanna do inner outer shell on 4 doors. the trunk the rear deck and possibly the roof Quote New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky. Link to comment Share on other sites More sharing options...
Desousa93 Posted January 29, 2014 Author Report Share Posted January 29, 2014 80 sq ft is the largest pack offered by second skin and considered a shop pack You should have enough to cover your entire car and then some, if you apply it properly also that bstock is a mix of damp and damp pro damplifer weighs .35pounds per square foot damp pro weighs .60pounds per square foot So the exact sq ft you will receive is an unknown variable that we need to effectively answer your question If the entire bstock is damp pro you should get around 66 sq ft if the whole stock is regular damp you should get around 114 sq ft A trunk kit is usually only 14-20 sq ft A car kit with other brands is usually only 40-60 sq ft that sounds good either way. i cou;d just sort it out then use the damp pro on the trunk and rear deck and the regular damp on the doors and other shit lol.. this is workong out better then i thought lol Quote New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky. Link to comment Share on other sites More sharing options...
Desousa93 Posted January 29, 2014 Author Report Share Posted January 29, 2014 (edited) ^^^ :roflmao: :roflmao: Edited January 29, 2014 by Desousa93 Quote New Build in the Making 1999 Infiniti I30 Limited if you break a rule and argue with n8 your going to get banned. suspended if your lucky. Link to comment Share on other sites More sharing options...
Aj11 Posted January 31, 2014 Report Share Posted January 31, 2014 my precious!!! Quote jvc deck stinger 1800 front hc 2000 kinetic rear 2 runs of 1/0g big 3/4 ct 60.4 2 ct 1400.1 ct EXO 15 d1 lots of deadner type r comps front stage 6 kicker tweets rear stage lots of great stuff coming soon ho alt more bats ct comps for front stage more deadner sweet amp rack lots of L.E.D lights new deck (thinking 80 prs, or flip out) Link to comment Share on other sites More sharing options...
97Jetta1637 Posted January 31, 2014 Report Share Posted January 31, 2014 no, 40 lbs will only cover the sound of one muffler bearing Quote #teamihop Two 12 inch DC XL's Carbon Fiber Cap Stetsom 7k Shell of box / baffle built by me Port / sealing the box by John Hone Fuck midrange Alpine-9886 http://www.stevemeadedesigns.com/board/topic/177428-97jettas-sql-trunk-wall-loudest-99-buick-century-custom-with-a-one-legged-owner/ price has no influence on how something sounds I told him to move the fucking port. they see me hoppin they stoppin they can't believe im so white and dirty It looks like you got so drunk, that someone came up and stole your leg. Link to comment Share on other sites More sharing options...
