96saturnsl Posted July 15, 2008 Author Report Posted July 15, 2008 ok thanks well if ppl can give me amp ideas while i sleep id be thankfull. i got 250-400 to spend. there ya go Quote
Guest aseanj52 Posted July 15, 2008 Report Posted July 15, 2008 Sorry.....like i said..... But here are 2 options........ Hifonics Bxi-2008D~~~~ $339 OR RockFord-Fosgate T10001bd~~~~$434 IMO it would be worth it to scrape the $34 extra for the Rockford Quote
96saturnsl Posted July 16, 2008 Author Report Posted July 16, 2008 is there any other ones? i just want a selection of a few Quote
96saturnsl Posted July 16, 2008 Author Report Posted July 16, 2008 http://cgi.ebay.com/ebaymotors/200-amp-Ira...ShippingPayment so that alt will run at 14.4v while at 2k rpms right? Quote
Guest aseanj52 Posted July 16, 2008 Report Posted July 16, 2008 http://cgi.ebay.com/ebaymotors/200-amp-Ira...ShippingPaymentso that alt will run at 14.4v while at 2k rpms right? It should......... Quote
RamenNoodles Posted July 16, 2008 Report Posted July 16, 2008 I dont think you are quite understanding what an alternator actually does. You can sit at that voltage without being at that RPM level. What happens at 2k rms is the alternator pulley is spinning faster creating more amperage. At 2k rpm, your alt will be at its max output which is 200amps If you are just sitting there with your system off but car running, you will still sit at 14.4 volts, you dont have to be at 2krpm to do this. All that an alternator does is charge the battery. Your really do not want to rely on your alternator to keep supplying a battery. You want to have some sort of decent storage as a reserve. As your batteries begin to get low, that power created from the alternator will begin to be recharged into your battery(ies) If you havent done so already you should invest in a new battery under the hood. For what you are running, you shouldnt need any other batteries in the trunk. Check out a Kinetik 1800 as a starting battery. Quote Diablo Audio Technologies Fi Car Audio Ascendant Audio
96saturnsl Posted July 16, 2008 Author Report Posted July 16, 2008 I dont think you are quite understanding what an alternator actually does.You can sit at that voltage without being at that RPM level. What happens at 2k rms is the alternator pulley is spinning faster creating more amperage. At 2k rpm, your alt will be at its max output which is 200amps If you are just sitting there with your system off but car running, you will still sit at 14.4 volts, you dont have to be at 2krpm to do this. All that an alternator does is charge the battery. Your really do not want to rely on your alternator to keep supplying a battery. You want to have some sort of decent storage as a reserve. As your batteries begin to get low, that power created from the alternator will begin to be recharged into your battery(ies) If you havent done so already you should invest in a new battery under the hood. For what you are running, you shouldnt need any other batteries in the trunk. Check out a Kinetik 1800 as a starting battery. ok ill look into one. this a good deal or nah? http://cgi.ebay.com/ebaymotors/Parts-Acces...p3756.m14.l1318 Quote
