RollinSoLow Posted October 14, 2008 Report Share Posted October 14, 2008 (edited) I have 2 mint cd players from the mid 90's that where said to have the best transports ever built and still to this day works flawless both have been serviced from eclipse and was put away for an old school build but i am no longer able to do installs nor do i have the time to complete the installs along with about 6 old school lanzar optidrive amps before they was bought out by pyramid the esn is not active so you can use your own key cd to make it active 1. The output voltage is only 2.7 volts not 4 volts. Kind of low, but should be a problem in a well design system. If you what a hotter signal run it into a high quality line driver. 2.Both head units output impedance is 22 ohms Now this is a great spec. Can you say a super clean signal.Most head units out are 150 ohms to 330ohms 135.00 each plus shipping if you have any question please feel free to ask Edited October 14, 2008 by RollinSoLow Link to comment Share on other sites More sharing options...
