Fi Car Audio
As you know this is my setup (I just posted it for people who didnt know)
This is my (Soon To Come) setup is it good or not?
SUB:(1) 18'' Fi.BTL (Fully Loaded) D2,cooling,hixm coil,induct heat ring,daily
AMP:(1) AudioQue 3500D (3500 Rms @ 1 Ohm!! & BTL's are recommended @ 2000 Rms) [is the amp good or what?]
its getting the whole 3500 rms
http://www.audioque.com/aq/AQ3500D.htm
http://www.audioque.com/aq/images/AQ3500D/AQ3500Dguts.jpg
(4) Screws for terminals (Better solid connection no leaks)
Enclosure:(1) [Ported] 6 Cuft. (After displacemant) Tuned to 32hz. (MAYBE) 3/4 MDF
Thats my setup but my main question is how much of a db differnce is a enclosure thats tuned to 32hz. from a enclosure thats tuned to 34hz. I love loud music but I want it to get deep as well (I'm not spl just daily) so whats best?
For A lucky quess do you think I'll hit @ leats 149db's if tuned to 34hz.
Do you think I should get removable ports like 27hz,32 hz,33hz,35hz, or dont do that just keep a regular port?
P.S:This is my budget so please dont ask for anything more expensive
Very Very Soon 2 Come???
(1):2002 Chevy Blazer Xtreme (2-dr. with Sunroof)
(4):15'' Orion Hcca's
(1):Stetsom V 14K2D
(6):Kicker PKD1 (Ampkit)
Ported:14 Cuft. (After all displacements) Tuned to 34hz. 3/4 MDF
(8):Screws for terminals (Better solid connection no leaks)
(1):Dynamat xtreme license plate kit
(1):Kenwood eXcelon KDC-X492
(3):300amp HO Alternators
(4):Kinetik HC 3800 Batts.
(1)Rockford Fosgate Power T8004 (For Mids & Highs)
(4)Rockford Fosgate Power T162S (Mids & Highs)
(3):Kicker PKD4 Ampkit (For Mids & Highs)
(1):Kinetik HC 1800 (under the hood or yellow top)
(1):Viper 5701 (p/n 5202V) ALARM
Big III will be done (beefing up my electrical system) etc.
Goal:154.9db-159.5db
Port options are good for Comps to Daily driver. Till you know where your car peaks out at use adjustable ports to see. All I do is demo's so our hummer is tuned to 30htz.
missinglinkaudio
The United States Marine Corps. When it absolutely, positively has to be destroyed overnight - even if "it" belongs to the base commander...
Okay thanks:) Do you know how much removable ports costs? Also what websites can I get them from?
(1):Stetsom V 14K2D
  • Who's Online   1 Member, 0 Anonymous, 664 Guests (See full list)
