Please Help Meca Class What Class Will I Be In
Find the point at which you DON'T pop the fuse and don't play higher than that. ;)
You can use the 40A if you know where to set your volume.
id pop it fast, for sure,, that would put me at 876 = as-2 class, maxx is 1000
id like to do as2, but it says i can use 2 fuses
if i use 1-50 x 10 + 476 = 976, just under the 1000 limit for as-2
but i can use 2 fuses, so does that mean i can run 2 fuses holders inline next to the amp both with 50 amp fuses in them ?
Edited by BassBoy69
144+ DB'S OUT OF A CONVERTIBLE
12" Funky Pup Subwoofer (The worlds most powerful subwoofer)
6" Aero Ported Box
Hifonics - Bxi2010-D
Pioneer Deck
RD Audio - Front Speaker
Rockford Fosgate - Rear Speakers
KnuKonceptz - 0 Gauge Wire
KnuKonceptz SS Karma - 10 Gauge Sub Wire
KnuKonceptz - Krystal Kable Rca
Big 3 - Upgrade - 0 Gauge
Kinetik - Hc1800 Battery
o shit i think i tottaly mis read your messages wrong,
I have to do this, tell me this is right..
78.53982 = 1 -10" subwoofer thats what meca says a round 10" is.
90 amp fuse x 10 = 900 + 78.53982 = 978.53982 ?
978 out of a max of 1000 allowed in as2 class
Edited by BassBoy69
6" Aero Ported Box
Pioneer Deck
yes that is correct,,,BTW try to keep your fuses as even as possible like a 50 amp and a 40 amp
'If it ain't broke, don't fix it,' unless you're a tweaker, and in that case you already fixed it ten times and it's still broken. - Dave Mustaine
ok so to make sure i can run 2 different size fuses and = 90 amps,
but ill have my main power wire go into fuse holder #1 with 1-50 amp, and then 4 inches of new wire leading into fuse holder #2, with a 40 amp in it,, exiting out with a few extra inches into the amp?
6" Aero Ported Box
Pioneer Deck
  • Who's Online   0 Members, 0 Anonymous, 394 Guests (See full list)
