BassBoy69 Posted February 12, 2009 Author Report Posted February 12, 2009 (edited) Find the point at which you DON'T pop the fuse and don't play higher than that. You can use the 40A if you know where to set your volume. id pop it fast, for sure,, that would put me at 876 = as-2 class, maxx is 1000 id like to do as2, but it says i can use 2 fuses if i use 1-50 x 10 + 476 = 976, just under the 1000 limit for as-2 but i can use 2 fuses, so does that mean i can run 2 fuses holders inline next to the amp both with 50 amp fuses in them ? Edited February 12, 2009 by BassBoy69 Quote 144+ DB'S OUT OF A CONVERTIBLE 12" Funky Pup Subwoofer (The worlds most powerful subwoofer) 6" Aero Ported Box Hifonics - Bxi2010-D Pioneer Deck RD Audio - Front Speaker Rockford Fosgate - Rear Speakers KnuKonceptz - 0 Gauge Wire KnuKonceptz SS Karma - 10 Gauge Sub Wire KnuKonceptz - Krystal Kable Rca Big 3 - Upgrade - 0 Gauge Kinetik - Hc1800 Battery
BassBoy69 Posted February 12, 2009 Author Report Posted February 12, 2009 (edited) o shit i think i tottaly mis read your messages wrong, I have to do this, tell me this is right.. 78.53982 = 1 -10" subwoofer thats what meca says a round 10" is. 90 amp fuse x 10 = 900 + 78.53982 = 978.53982 ? 978 out of a max of 1000 allowed in as2 class Edited February 12, 2009 by BassBoy69 Quote 144+ DB'S OUT OF A CONVERTIBLE 12" Funky Pup Subwoofer (The worlds most powerful subwoofer) 6" Aero Ported Box Hifonics - Bxi2010-D Pioneer Deck RD Audio - Front Speaker Rockford Fosgate - Rear Speakers KnuKonceptz - 0 Gauge Wire KnuKonceptz SS Karma - 10 Gauge Sub Wire KnuKonceptz - Krystal Kable Rca Big 3 - Upgrade - 0 Gauge Kinetik - Hc1800 Battery
RHoughton1 Posted February 12, 2009 Report Posted February 12, 2009 o shit i think i tottaly mis read your messages wrong,I have to do this, tell me this is right.. 78.53982 = 1 -10" subwoofer thats what meca says a round 10" is. 90 amp fuse x 10 = 900 + 78.53982 = 978.53982 ? 978 out of a max of 1000 allowed in as2 class yes that is correct,,,BTW try to keep your fuses as even as possible like a 50 amp and a 40 amp Quote 'If it ain't broke, don't fix it,' unless you're a tweaker, and in that case you already fixed it ten times and it's still broken. - Dave Mustaine
BassBoy69 Posted February 12, 2009 Author Report Posted February 12, 2009 yes that is correct,,,BTW try to keep your fuses as even as possible like a 50 amp and a 40 amp ok so to make sure i can run 2 different size fuses and = 90 amps, but ill have my main power wire go into fuse holder #1 with 1-50 amp, and then 4 inches of new wire leading into fuse holder #2, with a 40 amp in it,, exiting out with a few extra inches into the amp? Quote 144+ DB'S OUT OF A CONVERTIBLE 12" Funky Pup Subwoofer (The worlds most powerful subwoofer) 6" Aero Ported Box Hifonics - Bxi2010-D Pioneer Deck RD Audio - Front Speaker Rockford Fosgate - Rear Speakers KnuKonceptz - 0 Gauge Wire KnuKonceptz SS Karma - 10 Gauge Sub Wire KnuKonceptz - Krystal Kable Rca Big 3 - Upgrade - 0 Gauge Kinetik - Hc1800 Battery
