Posted (edited)
Would another batt. help my voltage drop? When i get to slamming the system it will drop down to 12.9-13.0, in the mornings my voltage is 15.1-15.0 then when it warms up during the day it settles down to 14.3. Would another batt. help or what other options is there, help me out guys i want to be ready for the SOCAL King Of Cali comp.
Edited by CHINO11550
H/U Pioneer deh80prs w/ HRT iStreamer Ipod DAC
Front stage is active, 4 Morel Elate 6.5" & 8 CDT DRT26 tweets
amp running 4mids, Mosconi Audio 300.2
amp running 8tit & alum tweets, Mosconi Audio 200.2
8 12" Ascendant Audio Chaos. amps 2 Digital Designs M4'z
box is a 4th order band pass
batts. 1 XS Power D3400 under hood,6 D3100 in back
2 XP 370 amp DC Power alts.
MLA module 15+volts
All in a 97 2door Tahoe LT
2010 West Coast Reg. 140-149.9 Bass Race Champ
Team Bass Hz
thats not terrible voltage drop, but as long as you alternator can handle charging the batts that u have than it cant hurt to add more powa.....do it.
2000 Eddie Bauer Expedition:
Alpine CDA 9883
2x 18" DC lvl 4 D2
10.7 cu ft box 33hz
knu 1/0 wire
amp: Kicker ZX2500.1
Kinetik
FO SHO BRO!!!!!
do big 3 if u havent
Already done.
MLA module 15+volts
Team Bass Hz
your voltage seems fine, you can always add another battery as long as your alternator can charge it. your voltage is always high when your engine is cold though
So can a 200 amp alt charge 3 big batts
MLA module 15+volts
Team Bass Hz
How do I calculate what alternator do I need to charge certain battery ?
Good question. :unsure:
MLA module 15+volts
Team Bass Hz
Or would it be better to put in my second alt. The second alt is only 90amps.
MLA module 15+volts
Team Bass Hz
