Joeskey Posted May 20, 2009 Report Share Posted May 20, 2009 Looks good man, cant wait to see more progress in this ride! and yea i think that might be a good idea, painters tape and fiberglassing, try to make the glass as strong as possible thou so that corner dont literally BURST! lol Quote "never drive faster then your guardian angel flies... good think my guardian angel drives a twin turbo ed beast" "its time has come for those who are different to stand united" Link to comment Share on other sites More sharing options...
03protege Posted May 21, 2009 Author Report Share Posted May 21, 2009 Looks good man, cant wait to see more progress in this ride! and yea i think that might be a good idea, painters tape and fiberglassing, try to make the glass as strong as possible thou so that corner dont literally BURST! lol Thank you very much, got a small update in second post Quote Link to comment Share on other sites More sharing options...
KzA Posted June 23, 2009 Report Share Posted June 23, 2009 Looks good man... You still running the stock alt? Ive got a Audiobahn A1500HCT running off of my stock MP3 alt and I get voltage drops down to like 11 volts... Havent even put in an Amp for Mids and Highs yet.. Quote Link to comment Share on other sites More sharing options...
t-roy Posted June 23, 2009 Report Share Posted June 23, 2009 Heres the link to part 1 if you wanna check it out. http://forum.realmofexcursion.com/showthread.php?t=43542Well its that time again, the old system could hold its own but as most all (if not all) of you know the shit won't cut it forever. Alot of my gear will remain unchanged for the time being with the exception of the subs. Highs: 4 pairs of RF 3 ways glassed in front doors Subs: 3 Fi SSD's (uac branded ones) Amps: T20001 T3002 (a little beast amp for sure) Headunit: Pioneer F700bt Enclosure is being built inside vehicle to give me the room necessary. If I did my math right it should be right around 4 cubes at 31hz. So real quick shitty videos of the car http://s201.photobucket.com/albums/aa62/03...nt=MVI_0478.flv http://s201.photobucket.com/albums/aa62/03...=MVI_0481-1.flv This picture show how much extra trunk space i will have. I went from 4ish cubes net to 5.2 cubes net and gained another 10 inches of trunk space. Throwin down that ebony stain (not sealed yet) Today's work Got a few pieces attached. Since I cant screw the wood together (except the port and front peice) im using these little metal braces. They made it alot stronger than I thought they would. Before the back goes on ima fiberglass it all. what are those brackets called exactly? where did you buy them? how much? Quote Link to comment Share on other sites More sharing options...
