i did try one sub and nothing happened...
it was working fine today with my old amp i just disconnected it and now nothing happens...
are the subs blown
I would say try switching the negatives on the speaker outs, just for the hell of it. See if that works.
EDIT: BUT ASK OTHER PEOPLE FIRST! I DON'T HAVE EXPERIENCE WITH THIS AMP!
[/disclaimer]
Edited by ktownsdriftking
Too many projects, too little time...
but look at the manual. do i need 2 rca connections with a y adapter for the input.. this thing is confuseing
some headunits have a mono subwoofer output, thats what the Y splitter would be used for.
well its ot the rca cables i took the headunit out and it says output and my cables are connected at output? i will till tomorrow morning when everything clears up its raining and shit so ill just hold off till tomorrow...
sometimes with the hifonics amp if the remote line is not tighten all the way or
some of the insulation is touching the remote hold down down screw they wont work
i know it has nothing to do with sub output but my buddy has one and thats what was happening.
Also make sure impendce is correct or you will burn up the speaker out put like i did my with 1608
98 Dodge Durango
12 000K 50/55W Headlights
12 000K 35W Fog lights
HU Panasonic CQ-VX100 7" Reciever
(1) Fi SSD 18" Fully Loaded
(1) Ported box 33hz
(1) Soundstream TRX1500D
(1) Soundstream TRX2.440
(1) RE 6.5" Component Set
(1) Rear battery
Big 3 in 0/1 gauge
2 runs of 1/0 Gauge wire
250A Alt soon..
did u check ur ground make sure its good and the wire isn't shot. i had the same problem awhile back hooking up a friend system. my buddy blew a solo baric in the ride and we put 2 rockfords in there with a new amp on the old wires. well we got power but no sound, come to find out the ground was bad the whole time so test ur ground check it out and see if that might be ur problem
well, i hooked up my old amp to it and one sub came on. only because i connected one sub.
so i pulled it out of the box and the subs were connected still they diddnt vibrate off or anything.
so then i hooked the hifonics amp directly to the sub without the box and nothing came on.
after that i hooked up my kenwood amp directly to my sub and it came on.
what now...
  • Who's Online   1 Member, 0 Anonymous, 469 Guests (See full list)
