Hii Steve i'm from caraudioclub and i wondering if you can help me about an amp..i have 4 15'' Earthquake TremorX 1000watt 500Rms...i wanna find an amp to play those beast's// :rolleyes: :rolleyes: I'm Waitting
Team CarAudioClub...
Earthquake TremorX 15'' x4
Special Thanks to Steve Meade for Join!! Thank you Bro!
Guest Nismofreak
okay you can get a 2,000rms amp to hook up four subs at 1-ohm or buy a 2-channel 1,000 rms for each channel at 1-ohm and buy 2 amps.
# MODELTremorX-154 1500 watts
# Stitched leads
# Spring loaded speaker connections
# Anti wobble cone construction
# TCT Technology (Turbine Cooled Transducer) for high effeciency output.
# Military grade single 4-Ohm voice coil
