im still looking for the source i havent found it yet
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
1 optima yellow top (rear)
1 xs power 5100r (front)
big 3 and 1 run 1/0 stinger wire
my build
my rebuild
ground noise is comming from my h/u rca outputs the noise filter took it away but it took away my midbass also
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
Have you tried grounding the shielding of your RCAs?
Wrap a small gauge wire around the shielding of the rcas where they connect to the HU (left & right, sub too if you have one) and then run those wires to ground.
12 - 12"s in the STAY PUFT 1989 Chevy Astro
Build & Comment Log
Un-Interrupted Build Log
YouTube Channel
Chevy Trailblazer 5.1 Dolby Digital DTS Install
You have a beard of a mysterious sea captain. I would follow you to hell and back.
im going to try that in the morning. does that just happen with kenwood dvd decks alot? the rca coming from the deck going bad ? i know this happens with pioneers but i thought kenwood was good about that.
thanks alot you have helped me alot
i tried running the rca straight from the mp3 and i had no noise.
also i had considerably more noise when i unplugged the antennae from the h/u
i tried the filter but it took away my midbass what do you think i should do next
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
it comes and goes now so i think it is just the h/u outputs going bad
current set-up
kenwood ddx 712
clarion eq
focal 165 k2p front
focal 165v2 rear
2 re audio sexxx 12
us amps md3d
us amps md42
my build
my rebuild
  • Who's Online   1 Member, 0 Anonymous, 789 Guests (See full list)
