kl0wn Posted January 6, 2010 Report Share Posted January 6, 2010 I think i can hit a 2000 in the front, do you think that would be good enough? and if the 2000 doesnt fit in the space that the current battery is now...can u put it somewhere else under the hood? If you got room somewhere else to add a battery under the hood, and it won't interfere with anything nor be in the way that's fine. If it won't fit anywhere under the hood, you can just throw it in the back beside your amp. The 2000 will be fine if you are just running the aq1200d. I'm not sure on the other post about running the other stuff, but I would just add another battery on top of that 2000, like a 800-1400. Then with that and the big 3, you should be fine. I am using the aq1200d and I am doing perfectly fine with what's in my signature for electrical. Quote 06 Mini Cooper S Sundown, SoundQubed Cadence, XS Power 151s Sealed 155s Outlaw Windshield @ 37hz Link to comment Share on other sites More sharing options...
Jwilson40 Posted January 6, 2010 Author Report Share Posted January 6, 2010 I'll probably just leave my battery in the front and add the 2000 then to be safe...thanks a lot. Quote Link to comment Share on other sites More sharing options...
