Well last night i took apart the sub from the box and everything was fine. All wires running good. It has to be the amp cause i went to a buddies house to plug in his sub, and when we did the same exact thing happened. So... Im at a wall. :censored:
Guest Scylloga
Is it possible to hooke the amp up using your buddies rcas? it could be your rcas causing the problem.
