where exactly do i run all these wires through? drill a hole in the trunk and go under the car? or what
look for a rubber grommet that has wire goin into the car you can use that or drill a hole make sure if you do that you use grommets to keep the wire from chaffing or you can run it under the car and into the trunk
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
not always, they run along one side of the car under the carpet. but under is an option as 1/0 can sometimes be a pain in some applications. but you want to run it so that it cant get cut or pinched and end up grounding out on the chasis. but the rca's and remote wire can easily be run inside under the carpet.
1998 jeep grand cherokee
future teardown and rebuild:
2-15.4 orion hcca's
sub amp undecided
2 sets of components
1-concept amp (mids/highs)
undecided h.o. alt
2-yellow tops
o.. ive already had subs in my car... I have rcas remote and amp power wires running in my car and I have a ground
oh, good deal.
2-15.4 orion hcca's
sub amp undecided
undecided h.o. alt
2-yellow tops
  • Who's Online   0 Members, 0 Anonymous, 1486 Guests (See full list)
