tb300m99 Posted March 22, 2010 Author Report Share Posted March 22, 2010 thankss for all the advice i get the sub tomorrow and il post how it worked. Anyone drive a 300m? Quote Link to comment Share on other sites More sharing options...
melonhead Posted March 22, 2010 Report Share Posted March 22, 2010 The amp does 460 at 1 ohm and sub holds 500. Where are you guys getting 300 at? Quote Link to comment Share on other sites More sharing options...
tb300m99 Posted March 22, 2010 Author Report Share Posted March 22, 2010 regal would you recomend the 460 at 1 ohm? Quote Link to comment Share on other sites More sharing options...
sqsux Posted March 22, 2010 Report Share Posted March 22, 2010 (edited) The amp does 460 at 1 ohm and sub holds 500. Where are you guys getting 300 at? http://www.crutchfield.com/S-zNkwNwiTjJ2/p_113KAC7201/Kenwood-KAC-7201.html 4ohm stable bridged http://www.sonicelectronix.com/item_47_Alpine+SWR-1221D+Type+R+DVC+2-Ohm+12-.html 300rms 1000max Edit: nvm thats the 1221 you're right about 500rms, either each coil to each channel or 4ohm bridged Edited March 22, 2010 by vengfuldev Quote Start out boxy, shape as you move along. Dc Audio Team Fur Link to comment Share on other sites More sharing options...
Guest Posted March 22, 2010 Report Share Posted March 22, 2010 The amp does 460 at 1 ohm and sub holds 500. Where are you guys getting 300 at? where in the hell did you see 1 ohm stable? it clearly says "460 watts RMS x 1 bridged output at 4 ohms" wire the type r in series bridged. end of story Quote Link to comment Share on other sites More sharing options...
Freshman6969 Posted March 22, 2010 Report Share Posted March 22, 2010 You can take de donkey or you can take de tram. Theyre all de same priice. i fucking love you man, siged<3 this made me lol for awile Quote Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k! Why would you EVER WANT flex?huh?...flex is what can make the lows lower and more air being pushed correct? My FeedbackJeep-BuildlogPT LOSER buildlog Link to comment Share on other sites More sharing options...
melonhead Posted March 22, 2010 Report Share Posted March 22, 2010 where in the hell did you see 1 ohm stable? it clearly says "460 watts RMS x 1 bridged output at 4 ohms" wire the type r in series bridged. end of story My bad. I read it correctly but didn't type it out correctly. lol Quote Link to comment Share on other sites More sharing options...
