fnaciancen21 Posted November 26, 2011 Report Posted November 26, 2011 just started to do my rebuild on my 96 4 dr blazer, just order two 18" ssa zcons ,maybe getting two more. the plan is to build a wall for daily use.still now sure about the amps, low on funds this is what i been up to the past two weeks. old setup was a 18" kicker solox with two db drive pd 2000s. tear down! New orillys relabeled deka 9a31 battery
fnaciancen21 Posted November 26, 2011 Author Report Posted November 26, 2011 got a new battery for under the hood, xs power d3400
fnaciancen21 Posted November 26, 2011 Author Report Posted November 26, 2011 sold double din head unit to raised funds This came in a weekago, powerwerx zero gauge welding wire. it is smaller the my kicker and Memphis zero guage. order 50 ft to run 3 runs of (-) , already have 2 runs of (+) one memphis and one kicker hyperflex , will be adding another memphis run from the alternator to the back for a total of 3 runs each. also have 2 zero gauge ground to the chassie in the rear. lots of expanding foam called for help
fnaciancen21 Posted November 26, 2011 Author Report Posted November 26, 2011 audiotechnix 60 mil sound deadener order 50 sq ft
fnaciancen21 Posted November 26, 2011 Author Report Posted November 26, 2011 Running zero guage and sound deadener Memphis zero gauge compared to powerwerx 0 gauge wielding wire
fnaciancen21 Posted November 26, 2011 Author Report Posted November 26, 2011 Got my DD-1 no more distortion
Jd1102 Posted November 26, 2011 Report Posted November 26, 2011 do you have any vids of the solo x and keep up good work
fnaciancen21 Posted November 26, 2011 Author Report Posted November 26, 2011 do you have any vids of the solo x and keep up good work im not sure, ill look for some and post them if i find them
fnaciancen21 Posted November 26, 2011 Author Report Posted November 26, 2011 order some dampifier pro last night a door kit and a trunk kit, save around 60-90$ cant wait for it to get here. its my first time using sound deadener hopefully it work out ok. i problem im having is that my high ouput alt(excessive amperage 300 amps) is charging at 13.8 hot.voltage drop was very low. what would be my best option to make it charge aroung 14.8 -15 volts? mla,vcm or mechman voltage boast, ect?
fnaciancen21 Posted November 26, 2011 Author Report Posted November 26, 2011 how many dekas battery in the back for 6-7 kw?
