Kenwood 9105D
Jessica
I have the same amp tuned with a dd-1 on track 5 and it slams a single sa-12 wired to 2ohms pretty well. id def buy the amp again. once i pulled the back cover off i felt like there wasnt much inside. oh and i read that it only draws 57amps max,so i swapped out my 100amp inline fuse for a 60 and it hasnt blown it yet. with this system i get alittle windshield flex in my 4dr civic. thanks for posting the gut pics
Headunit in mustang deh-p7000bt (Max undistorted volume 59) Headunit in gti deh-6000ub (max undistored volume 59) Amp=saz-1000d (Gain set with dd-1) Subwoofer= psi platform 3 18" (dual 1ohm)
it's built on the same concept the rockford constant power series are. It suppose to do the same at 2ohms as 1ohm and do it effiecently. I can say that good airflow is critical with this amp. a lot of people complain it drops out when running full tilt over long periods. I see it could use better capacitance and if you have good air flow it will run full tilt no problem for extended periods and stay cool. It's a finicky amp and is not what i expect from a company like kenwood that use to rate amps at .01% distortion.
I am saddened that they have reduced build quality. It's sad to see a company that use to make such nice equipment sliding down this slippery slope of mass produced inferior products. Live and learn i guess.
I want to clamp mine to figure out how many watts its putting to my sundown. i would guess from what u clamped urs at 600w-700wrms. If i remmeber correctly I got 49.5volts clean on track 5 with the dd1 full tilt.
  • 7 months later...
had one caught fire bla bla , yea well dont overload these amps they dont like it
(- Ford Focus Titanium LW sedan )
REBUILD IN PROGRESS STAND BY
  • Who's Online   1 Member, 0 Anonymous, 848 Guests (See full list)
