The Saturn: 3 15's, AQ20 tons of fiberglass (Death-Horn) and low-lowz
After a long slumber it'll be back in action. Still have the AQ20 in hibernation and already have the first 15 on the way (you'll see what I'm going with when the first one arrives)
Starting today the saturn will be seeing steady work, though a lot of the work/progress will be pretty boring because it'll consist of taking the sunroof out to reinforce the ceiling and glass the whole roof of the car over and repainting it so it'll be solid and leakproof.
The interior/floor/everything will be slicked out to be one flowing surface inside, center console will be glassed in place, also flowing into the floor seamlessly etc etc.
I'm hoping I'll have enough time to get to the inside of the box, slick everything out, paint it, and cut a hole on each side of the enclosure with plexi to see inside (but no promises).
I have 4 pairs of components I'm hoping to get in as well but one pair has been in the saturn for years and years (lame)...so I may be hunting down another pair so everything's new. Reinforcing the front doors will be in order if the mids happen...may be heading to my buddy to weld inside the doors and then I'll reinforce/deaden further.
And once the sunroof is out completely/foam all cleared out I'll be getting to some lighting of some kind in the ceiling on the interior but havent decided on what I'm going to do there.
Anyways, here's a little I got done just now...
The pyles...all blown ...they actually weren't bad at all for what they're worth...
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
Got a bit tired of the foam+glass uptop so I moved inside and started sanding down the inside of the enclosure a bit and some of the floor...
Started planning out and getting my center console going, cutting ribs for the basic shape...(will be glassed right into the floor seamlessly)
These will eventually make the shape for the center console, then glassed around...
Team Tupperware
Fairly cleaned up...
Woh now...
Can see through the side of the horn...
Team Tupperware
Alright, the roof's almost completely cut away now...
Team Tupperware
Stuff I found in the basement...Could come in handy...
The first few times it went on I added chop mat to it but from here on out it should just be sand+resin mixture.
Team Tupperware
Let's see...what do we have here?!....something arrived today...
15" Fi SP4...
Team Tupperware
Spaced the fans off of the wall theyre mounted to...
Going to wire them to the remote along with a few volt meters throughout the vehicle...
Team Tupperware
Got it playing I installed the pair of sp4's that I already have and put them on my ol' trusty crossfire 1k @ 1 ohm. All I can say is that these subs are going to do disgusting things in this enclosure...even on just the 1k and the 3rd sub not here yet hairtricks would be a breeze...most likely with both windows down (not quite door-open worthy yet but will be ;) ).
Anyways, here are some sloppy pics of the sloppiness :( I'm really not pleased with how it'll come together for slamology but ive got to do what ive got to do...
Team Tupperware
The satty's back, bishes!
All wired up...
Cant wait for tomorrow
Team Tupperware
Alright, vids finally uploaded. Im not sure if it's doing it to everyone else but the framerate is absolutely horrid...? Not sure if it's just my old comp..? If so I'll definitely try and get some more vids when I can :redface:
The Saturn 2012 :: 5f2813c4.mp4 video by TheSatty - Photobucket
The Saturn 2012 :: 99ca9df4.mp4 video by TheSatty - Photobucket
The Saturn 2012 :: 99e2a278.mp4 video by TheSatty - Photobucket
The Saturn 2012 :: 3abe89eb.mp4 video by TheSatty - Photobucket
The Saturn 2012 :: b3d5f3d5.mp4 video by TheSatty - Photobucket
Team Tupperware
  • Who's Online   1 Member, 0 Anonymous, 1730 Guests (See full list)
