Ok so just set a friends saz 1500 on two x12's. I set the amp using the dd1 with the 40hz -10db track. Now just playing regular hip-hop the amps remote has a clipping light and its blinking on every hard bass hit. Should we turn down the gain use the track -5db? Idk how accurate that clipping light is.
Do you know what -10db overlap means? Just because you are listing to "regular hiphop" doesnt mean none of it was produced above -10db. So if you have a -5db recording your going to clip... unless you do a 0db overlap yoir going to run into clipping at some point. How much....? Depends if you go through every song you play in audacity and find out what levels its at.. a soft clip wont hurt...
05 dodge magnum rt
DEH-80PRS
Rockford fosgate T600.4
st200 tweeters
Sundown Neo Pro 6.5 v2's
2 Saz-3500v2- Toolmaker dual 1/0 inputs
2 Sundown ZV4 12" D1
1/0 Sky High Power wire OFC
3 XS D3100- Toolmaker battery terminals
Mechman 320 Amp Alt
Smd Voltmeter
KnuKoncept 1/0 OFC
  • Who's Online   0 Members, 0 Anonymous, 1233 Guests (See full list)
