Jordan Thurston Posted July 2, 2015 Author Report Share Posted July 2, 2015 Still got enough to do my doors up front so that should help the front speakers sound a little better Link to comment Share on other sites More sharing options...
jcarter1885 Posted July 2, 2015 Report Share Posted July 2, 2015 Can you get the bumper off or get behind to put some foam/thick rubber between the bumper and brackets. Nav-TV Zen V Audio Interface AudioControl DM-608 (2) Stevens Audio Neo-Comp Full-Size Horns (4) Faital Pro 6PR160 6.5" AudioControl LC-6.1200 (1) Fi Neo 4.7 15" D2 in 3.74 Cubic Feet @ 27.70 Hz Ampere Audio AA3800.1 Odyssey ODP-AGM48 Battery (Starting) Odyssey ODX-AGM31 Battery (Trunk) Big 3 - 2\0 Welding Cable, KnuKonceptz Speaker Wire & 1/0 Power Cable, NVX RCAs, Second Skin (Speaker Tweaker Pads, Damplifier Pro Mat), Diode Dynamics LEDs Link to comment Share on other sites More sharing options...
Jordan Thurston Posted July 2, 2015 Author Report Share Posted July 2, 2015 Can you get the bumper off or get behind to put some foam/thick rubber between the bumper and brackets. I've put pieces of rubber and stuff between the bumper and brackets but they just fall out I can get behind it to spray expanding foam but I want it to be the stuff that doesn't dry hard im afraid if I put to much in there it will make my bumper bulge out Link to comment Share on other sites More sharing options...
Loops12 Posted July 2, 2015 Report Share Posted July 2, 2015 I have a 09 impala, For some reason I have a lot of rattles to and I use deadner on the trunk. Let me know what u use. I was thinking of using the foam. Link to comment Share on other sites More sharing options...
Jordan Thurston Posted July 3, 2015 Author Report Share Posted July 3, 2015 I have a 09 impala, For some reason I have a lot of rattles to and I use deadner on the trunk. Let me know what u use. I was thinking of using the foam. I'll let you know what I decide im gunna grab some stuff tonight maybe and try and do it tomorrow Link to comment Share on other sites More sharing options...
Jordan Thurston Posted July 3, 2015 Author Report Share Posted July 3, 2015 Could you share the necessary steps for removing the front door trim panels? A friend of mine has a '12 Impala and wants to install new door speakers. Thanks. Ok I got my deadener installed in the doors I took a few pics of the bolts you need to get to to take the door panel off You have to pop the red peice of and there is a 7 mm screw behind it There's 2 10 mm bolts you have to remove here there under the rubber piece Then you Pop this plastic piece off and there is a torx screw behind it not sure what size I used a flat head screw driver to take it out You also have to take this triangle piece off it just pops off Once you get that off just pry around the edge of the door with a screw driver and it will pop off there is a plug you have to unplug and you have to pop the cable from the door handle out its pretty easy just push one tab through the hole then use a screw driver to push the other tab and it will come right out Link to comment Share on other sites More sharing options...
Jordan Thurston Posted July 3, 2015 Author Report Share Posted July 3, 2015 I forgot to take pics of the sound deadener installed in the door really don't wanna take it apart just to take pics it did help a lot sounds a lot better now Link to comment Share on other sites More sharing options...
Loops12 Posted July 3, 2015 Report Share Posted July 3, 2015 Install looks great, like the step by step. Link to comment Share on other sites More sharing options...
Stephen13 Posted July 3, 2015 Report Share Posted July 3, 2015 Thanks for taking the pix JT. They'll come in real handy when my buddy gets his new speakers. 2011 Chevy Silverado LT 5.3L 4x4 Ext.-cab "Enjoy yourself. It's later than you think." Link to comment Share on other sites More sharing options...
Jordan Thurston Posted July 3, 2015 Author Report Share Posted July 3, 2015 Thanks for taking the pix JT. They'll come in real handy when my buddy gets his new speakers. Not a problem took a little longer than I thought but i finally got to it Link to comment Share on other sites More sharing options...
