The Saturn: Cant Stop There (dual 18's Upgrade)
It's about time for an upgrade...dontcha think? :D
This upgrade will consist of losing the 18" BTL and a pair of 18" Omega's will go in the backseat area, firing forward behind each seat with the port firing up in the rear deck (trying the keep everything at the window line and within the factory dimensions of the rear deck). Still running off of the SoundStream XXX10000 (1 ohm), I may be getting another down the road plus some more D3100's (but that'd be a while...nearly 2 grand for that upgrade :crap:).
For the enclosure im looking to get a good 5.5 cubes net per sub and a 210 sq inch port tuned to 31Hz :cool:
Here's a sketch of what it should be like:
Posted Image
My first 18" Omega is already here...going to order the second once I have the money, shortly down the road:
Posted Image
Posted Image
Posted Image
Some deadening was done to the back-half of the car (almost 2 rolls of raamat were used here):
Stripping away the headliner..
Posted Image
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
The strip of factory deadener...lmao, wow..(I didnt take off the front half of the headliner so I could still compete with the trunk setup while I was waiting)
Posted Image
Starting the deadening..
Posted Image
Second layer..
Posted Image
3rd layer..
Posted Image
I believe I got to 5 layers on the cieling portion..
Posted Image
Took off the 3rd brake light (it rattled too much and just didnt want it on)..
Posted Image
Exterior rear door panels came off..
Posted Image
(already had a layer of spectrum sludge from before on the inside)..
Posted Image
Posted Image
A bit of deadener there..
Posted Image
Team Tupperware
And a bit more for the door panel itself too..
Posted Image
Posted Image
Posted Image
Posted Image
Inside of the door got a good 3 layers everywhere and 4 layers in most spots..
Posted Image
Team Tupperware
All of the loops and parts to have the rear seats in were cut out along with almost the entire rear deck and more..
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Seat belts gone..
Posted Image
Posted Image
This bolt was a freakin b!tch!
Posted Image
Team Tupperware
How the deadening sits as of now..(even though the seat belts are still in, lol...)
Posted Image
Some more of the sub..
Posted Image
Posted Image
Team Tupperware
Getting setup for the base panel for the enclosure to be mounted to..
Posted Image
Fitting..
Posted Image
Posted Image
Posted Image
Got 4 all thread bars mounting this plus the existing pair of bolts from the seats...this thing isnt going anywhere :cool:
Posted Image
Posted Image
^going to be coating the nuts/allthread on the outside of the vehicle eventually)
Posted Image
Team Tupperware
Base panel mounted and foaming underneath to fill it all in..
Posted Image
Posted Image
Posted Image
Posted Image
Team Tupperware
Didnt get a pic of the excess all-thread cut off those mounting points :crap:...but got that done..
And today I went to Jon's house (he made my bracket for the alt in the AC position :) ) today to get an idler pulley put near the front alternator for better wrap. Ive shredded 2 serpentine belts now from big draws at low rpms...this should help once I find a belt for it..
The satty at Jon's :)
Posted Image
Posted Image
Posted Image
Posted Image
Idler in...but to get home I just bypassed it because I dont have a belt to fit around everything yet..
Posted Image
Posted Image
^The belt will go underneath the idler and back up to the alternator's pulley for better belt wrap..
Team Tupperware
shit.......do work
~Matthew
1998 Toyota Camry XLE V6 3L
(1) ScyTek Astra 4000RS-2W-1 2-Way Remote Start Alarm
with Shock and Proximity
(1) 20% Tint All Around (Gately Audio)
(1) 250 Amperage HO Alternator
(1) Big 3 Done In 1/0
(2) Kinetik HC2400 Power Cell
(1) Alpine IVA-D106 Receiver
(1) Peripheral Video Bypass Device
(4) Alpine SPS-17C2 Speakers
(1) Alpine KCE-422i iPod Control Interface
(4) Sheets Dynamat Extreme; for speakers
(1) 10 Square Feet Hushmat (Trunk & Rear Deck)
(4) DC Audio Level 4 15" D2 Subwoofer w/ Level 5 Coils
(1) Wall Built By David, Tuned to 32 Hz
(1) Rockford Fosgate T40001bd Amplifier
(1) Stinger 1/0 Wiring (2 runs of + 2 runs of -)
(1) Stinger Volt Meter
Had the beast out a while ago and snapped a few..:)
Posted Image
Posted Image
Posted Image
More as it happens :)
Team Tupperware
