Sold another batch so heres more... :D
Alright so I get these batterys locally and they are bad ass... Me and my buddys been using them for a while and love them so I thought i'd sell a few... I also get a bit of a deal and figured I'd pass that on as well. I can get a few of each, the big ones are the size of kinetik 3800, 134ah... Then the small ones are the size of like a hc1800... They are all AGM non-spillable batteries of course and are TANKS... Sacramento CA Area Pick Up Or Ship... Pm me for multiple deals of course. Also will take Offers and some Trades... So let me know...
Looks like about 10 of each on the pallets And then another pallet of the small C&D 75ah ones
Also like I said in other thread there will be 90Day Exchange warranty for anyone local but even if its past 90 days and you have a problem, let me know and i'll see what I can do.
Oh and also Refs.. I forgot but umm got a few on ca.com and then tons local... zfrerichs just picked some up, umm me, 99vic, and loganberry been running some for a few... Ummm know quite a few guys here personally and done deals such as alarms, boxs, iunno but ForEvrBumpn, B Slaps Yo Mama, civicman, colt 45, Noobtastic, zfrerichs, ect.. Team Nor*Cal Bass - 99vic, Loganberry, Ipod, thehoe92 Also got 200 or so 100% feedback on ebay and 99vic already said he'd put his superseller 100% feedback on the line for me as he will be the one getting a little discount on shipping the batts for me..
Prices And Also Open to Trades
C&D UPS12-475FR (134AH) - Sold No More
C&D UPS12-270FR (75AH) - 150 Shipped
GNB Splinter (75AH) - 160 Shipped
NPX-150R (40AH) - 90 Shipped
C&D Technologies Dynasty High Rate Series UPS12-475FR
Valve Regulated Lead Acid Battery
12V 134AH @ 20 Hr. Rate
12V 475WPC @ 15 min. rate, 1.67vpc
Features
10 year design life @ 25 degree C
2 year replacement Warranty
Absorbent Glass Mat Technology, AGM
Flame Retardent Polypropylene case
No restrictions for Ground/Air Transport, non spillable battery
Specifications
Dimensions = 13.57"L x 6.76"W x 10.93"H
Weight = 100lbs
C&D Technologies Dynasty High Rate Series UPS12-270FR
for UPS standby power applications
12V 75 AH @ 20 hr rate,
12V 282 watts/cell @ 15 min. rate
57lbs
Dimensions = 10.27"L x 6.82"W x 8.82"H
FEATURES
Flame-arresting one-way pressure-relief vent for safety and long life.
Thermally welded case-to-cover bond to eliminate leakage.
Absorbent Glass Mat (AGM) technology for efficient gas recombination of up to 99% and freedom from electrolyte maintenance.
Computer-generated grid design optimized for high power density.
UL-recognized component.
Multicell design for economy of installation and maintenance.
Can be mounted in any orientation.
Not restricted for air transport – Complies with IATA/ICAO Special Provision A67.
Not restricted for surface transport – Classified as non-hazardous material as related to DOT-CFR Title 49 parts 171-189.
Computer designed lead, low calcium alloy grid for minimal gassing and ease of recycling.
Case and cover available in both standard and flame retardant polypropylene.
Flame retardant polypropylene case and cover compliant with UL 1778 (optional)
GNB Sprinter S12V285F
12V 285WPC @ 15 min. rate, 1.67vpc
Features
8 year design life @ 25 degree C
3 year replacement Warranty
Specifications
Dimensions = 10.25"L x 6.85"W x 8.8"H
1300 ca
1130 cca
75 ah
63 lbs
NPX-150R
Enersys formally Yuasa NPX-150R battery are designed using proven gas recombination technology which removes the need for regular water addition by controlling the evolution of hydrogen and oxygen during charging. Gas recombination provides the user with freedom to use lead acid batteries in a wide range of applications.
Features & Benefits
• Design Life: 3-5 years @ 25ºC(77ºF)
• UL recognized
• Approved for shipping as non-hazardous, non-spillable
• Operates in any position
Applications
• Emergency Lighting
• General Electronics
• Medical
• Mobility
• Security
• Uninterruptible Power Supply
Technical Features and Benefits
Construction:
• The construction and sealing techniques of the Genesis NP battery guarantee leakproof operation in any position with no adverse effect to capacity or service life.
Electrolyte Suspension System:
• All Genesis NP batteries utilize an electrolyte suspension system consisting of a high porosity, glass fiber material which in conjunction with plates, totally absorb and contain the electrolyte. No silica gels or any other contaminants are used.
Gas Generation:
• Genesis NP batteries incorporate a built-in design that controls gas generation and induces recombination of more than 99% of gases generated during float usage.
Maintenance Free Operation:
• There is no need to check specific gravity of the electrolyte or add water to Genesis NP batteries during float service life. In fact, there is no provision for this type of maintenance.
Low Pressure Valve Regulated System:
• All Genesis NP batteries are equipped with safety release valves, designed to operate between 2 and 5 psi and automatically reseal. Hence, there is never an excessive accumulation of gas within the battery.
Heavy Duty Grids:
• Heavy duty lead calcium tin alloy grids provide an extra margin of performance and service life in either float or cyclic applications, even after repeated over discharges.
Cyclic Service Life:
• More than 1000 discharge/recharge cycles can be realized from Genesis NP batteries, dependent on the average depth of discharge.
Float Service Life:
• Genesis NP Series batteries have an expected life span of 3 to 5 years in float service applications.
Self Discharge - Shelf Life:
• The self discharge rate of the Genesis NP series at room temperature is approximately 3% of rated capacity per month.
Operating Temperature:
• Genesis NP Batteries may be operated over a broad range of ambient temperatures.
Deep Discharge Recovery:
• Genesis NP batteries recover their capacities even after repeated deep discharges.
Specifications
Chemistry Lead Acid
Voltage 12
Capacity 40,000 mAh / 40 Ah
Rating 480 Whr
Length 7.76 inch / 19.71 cm
Width 6.50 inch / 16.51 cm
Height 6.89 inch / 17.50 cm
Color Gray
Weight 34.2 lb / 15,512.78 g
Edited by Got_Bass89
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
hahahaha this totally caught me off guard!! spent the last few minutes figuring out what deal we've done. :D:good: But yeah Joey is a good dude and i've seen lots of these batteries floating around the lanes in the sac area and seem to be very powerful. GL on your sale man! :friends:
-Drew
Edited by Noobtastic14
uhoh_45 said:
Also little experience... My system in sig 60A Stock Alt... 12.0 drop at idle and 12.4-12.6 with rev.. 1 C&D 270 in back, Yellowtop up front...
99Vics Durango. 2 lvl4 /w 5 coil 18's off 3000.1 and Soundstream 4ch. Stock Batt up front Stock 90A Alt.. 2 GNB batts in back... 12.5 Drop Idle and 13.3 Drop Rev...
Loganberrys F150.. 2 lvl5 15s off stetsom 7kd and a 4ch... 3 C&D 270s in back.. Stock batt up front and stock 130A Alt... 12.4 drop idle.. Like 12.6-7 Rev
zferichs has the C&D 270 as front battery working great..
FULL TILT!!!! :D
Passport Build Here
-Drew
Was talkin bout know personally.. But ok noob off the list! :D
Passport Build Here
Bump it with a few more pics... Was floating them.. Showing 15.3 MLA is fine also for these bad boys.. Would show 14.4 too but charger wont do 14.4.
Passport Build Here
how much for local pick up??
PM Sent...
Also trades Im looking for right now is Kicker zx350.4 and Sundown saz1500... Also 2x 18's Havn't decided what to run yet :D Partial trade either side is fine too
Passport Build Here
Damn everyone went crazy for the other guys beat up batts for 110+ ship so if you got a OBO pm me...
Passport Build Here
hey hey thats only beat up cuz its in my car. the other ones are new and clean sitting on the pallet. wasnt tryin to be a dick and take your business but im out of a job and need all the money i can to pay bills and stay fed
Hey no hard feelings here bro.. If you can sell them cheaper than me thats all you... Nothing I can do about it... So good luck selling them.. Stay around get some posts and learn some stuff here and then you can sell later...
Passport Build Here
This topic is now closed to further replies.
  • Who's Online   1 Member, 0 Anonymous, 713 Guests (See full list)
