quick tube port question
I am redoing the front baffle on my enclosure for two Alpine S-10s. They are in separate chambers of about 1.3 cubes tuned to 34Hz. I am increasing the port diameter by an inch. However, this requires a longer port than my box. Could I just use a 90 degree bend inside the box to keep the port internal? Or should I just suck it up and run external ports?
Too many projects, too little time...
should be ok....i think
2010 IDBL Rookie 1 North American Champion
2009 IDBL Rookie 1 Fl State Champion
2009 EBB Fly Weight 3rd Place Fl State Finals
2006 Silver Grand Prix GXP :Diablo Audio Hellfire 1000.1, JL Audio 300/4, One 13W7, ZR650, VR690, JL Cleansweep setup.
Team Pure Pressure
It is fine. You can get standard bends and long bends (larger bend radius) at lowes. Use the long bends if they will fit.
Brian
Current system:
1997 Blazer - (4) Customer Fi NEO subs with (8) American Bass Elite 2800.1s
Previous systems:
2000 Suburban - (4) BTL 15's and (4) IA 40.1's = 157.7 dB at 37 Hz.
1992 Astro Van - (6) BTL 15's and (6) IA 40.1's = 159.7 dB at 43 Hz.
Is there a different way to measure length of the 90 degree bend? I need 21 inches to get a 33Hz tune with my box
if the the bend is pretty round ....so find the radius and calculated the circumference of the full circle and divide by 4
the length is the center of the port so take that into consideration also
Team Pure Pressure
Thanks for the help guys. Ports are glued together, waiting to be put in tomorrow. Can't wait!
*Prays for NO DAMN PORT NOISE THIS TIME!!!!*
Just a quick update to say that it works GREAT! No port noise at all, and that's with it firing into the cabin! Thanks guys! =D
  • Who's Online   0 Members, 0 Anonymous, 3202 Guests (See full list)
