booboo123 Posted February 11, 2011 Report Share Posted February 11, 2011 i just need to know if these subs can be ran sealed or ported and also the box that i want to build is 30h x 48w x 15d also its going in a ranger thanx for the info in advance Quote Link to comment Share on other sites More sharing options...
dugee81 Posted February 11, 2011 Report Share Posted February 11, 2011 they can go either way, ported or sealed. the dimensions you posted give to a little over 10 cu ft before displacement, what do you wanna tune it to? Quote 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm Link to comment Share on other sites More sharing options...
booboo123 Posted February 11, 2011 Author Report Share Posted February 11, 2011 they can go either way, ported or sealed. the dimensions you posted give to a little over 10 cu ft before displacement, what do you wanna tune it to? i was thinking like 35 Quote Link to comment Share on other sites More sharing options...
booboo123 Posted February 11, 2011 Author Report Share Posted February 11, 2011 anybody if someone could help me with this it would be greatly appreciated thanx Quote Link to comment Share on other sites More sharing options...
Guest Posted February 11, 2011 Report Share Posted February 11, 2011 AQ drivers are not meant to be put in sealed boxes Quote Link to comment Share on other sites More sharing options...
dugee81 Posted February 11, 2011 Report Share Posted February 11, 2011 AQ drivers are not meant to be put in sealed boxes i think he is gonna go ported. i would help more, i am just unsure of the amount of port area volume & per foot recommended for this woofer! Quote 200a alt. by Excessive Amperage hc800 under hood & 2 Deka 9a31 in rear 1/0awg + big 3 SAZ 3000D HDC3 18" @ 2 ohm Link to comment Share on other sites More sharing options...
Guest Posted February 11, 2011 Report Share Posted February 11, 2011 AQ drivers are not meant to be put in sealed boxes i think he is gonna go ported. i would help more, i am just unsure of the amount of port area volume & per foot recommended for this woofer! 16sqin of port per cubic foot. 3.0 to 4.5cuft box space recommended for their 15's Quote Link to comment Share on other sites More sharing options...
booboo123 Posted February 11, 2011 Author Report Share Posted February 11, 2011 AQ drivers are not meant to be put in sealed boxes i think he is gonna go ported. i would help more, i am just unsure of the amount of port area volume & per foot recommended for this woofer! 16sqin of port per cubic foot. 3.0 to 4.5cuft box space recommended for their 15's [/quote before displacement ill have 10.35 but i can make the box a little bigger if need be im just unsure about how to tune it but 35 sounds about right uh? Quote Link to comment Share on other sites More sharing options...
Guest Posted February 11, 2011 Report Share Posted February 11, 2011 before displacement ill have 10.35 but i can make the box a little bigger if need be im just unsure about how to tune it but 35 sounds about right uh? why would you need to make the box bigger? a single 15 needs 3 to 4.5cuft after displacements (assuming). just do that with the required amount of port area. you tune it by changing the height, width, and depth of the port. height and width determine port area. Quote Link to comment Share on other sites More sharing options...
