i just need to know if these subs can be ran sealed or ported and also the box that i want to build is 30h x 48w x 15d also its going in a ranger thanx for the info in advance
they can go either way, ported or sealed. the dimensions you posted give to a little over 10 cu ft before displacement, what do you wanna tune it to?
200a alt. by Excessive Amperage
hc800 under hood & 2 Deka 9a31 in rear
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
i was thinking like 35
AQ drivers are not meant to be put in sealed boxes
i think he is gonna go ported.
i would help more, i am just unsure of the amount of port area volume & per foot recommended for this woofer!
1/0awg + big 3
SAZ 3000D
HDC3 18" @ 2 ohm
16sqin of port per cubic foot. 3.0 to 4.5cuft box space recommended for their 15's
[/quote
before displacement ill have 10.35 but i can make the box a little bigger if need be im just unsure about how to tune it but 35 sounds about right uh?
why would you need to make the box bigger? a single 15 needs 3 to 4.5cuft after displacements (assuming). just do that with the required amount of port area. you tune it by changing the height, width, and depth of the port. height and width determine port area.
