Ok so i have a db drive 1000.1 amp which is rated
1x 1000 watts @ 1 ohm
1x 500watts @ 2 ohms
I currently have (2) 15's which are 4ohm subs hooked up to the amp which makes it 1 ohm?
Now does this mean that each subwoofer is getting 1000 watts or only 500?
i think the awnsers only 500? lmk im learning so please help a new audio guy out thanks!
It depends how you have your subs wired.
If the subs are single voice coil, you can only wire them down to 2 ohms if wired in parallel (8 ohm in series).
If the subs are dual voice coil, you can wire them down to 1 ohm if wired in parallel (4 ohm in series)
The "1x 1000 watts @ 1 ohm" is per channel. Since it's a monoblock, it is sending 1000 watts out of that one channel @ 1 ohm. Since you have two subs, that power will be split in half, sending 500w to each sub. Same goes if you have them wired to 2 ohms, it will send out 500/channel, or 250/sub.
Edit: If you're unsure about wiring, check out these two sites.
Single voice coil:
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=41
Dual voice coil:
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=42
Wall build: http://www.stevemeadedesigns.com/board/topic/174827-walled-taurus-with-lambo-doors/#entry2571893
real men dont use fuses :D
Neither do morons
Says the guy with lambo doors on his Ford Taurus.
  • Who's Online   0 Members, 0 Anonymous, 540 Guests (See full list)
