Alternator help
I have a 1978 F-150 xlt ranger and it has 460 with a 60 amp stock alt in it.
I am ungrading to the system in my signature and want some help with deciding an alternator to use.
Thinking of runnin the XS 2400 as a second battery to a yellow top d35 and wanna run a 140 amp alternator.
will voltage drop be a huge problem for the system tht i am putting in it.
The Build:
-2002 Dakota ext.
-Walled off tuned to 32hrtz
-3 SA-15s dual 2 ran down to .33ohm
-2 batterys
-stock alt
-AQ 2200
-Knu 1/0 runs and big three
Loud by Design FTW!!!!
i'd definitely upgrade the alt if you plan on running 2k. 2 batteries should pair up well. also the big 3 as well.
yea big 3 is already done. just askin if tht 140 amp alt upgrade will not have a ton of volt drop with those two batteries.
The Build:
-2002 Dakota ext.
-2 batterys
-stock alt
-AQ 2200
you should be fine, but if you're that concerned then you can upgrade to some model in the 200 amp range.
kk. thx for the help.
The Build:
-2002 Dakota ext.
-2 batterys
-stock alt
-AQ 2200
  • Who's Online   0 Members, 0 Anonymous, 1295 Guests (See full list)
