no run from alt to positive on the battery negative from batt to a solid point in the car from engine ground to the negative on the batt as well
06 chrysler 300C Hemi
one mmatts dreadnaut 15 powered by a planet audio vx 2200d
fosgate p200 running planet audio 8" midbass drivers and super compression tweeters
stock battery and a stinger spv44
Irragi 300 amp alternator
big 3 1/0
http://www.stevemeadedesigns.com/board/topic/55075-system-in-my-300c/page__view__findpost__p__763656__fromsearch__1
But the wires from the positive runs to the fuse box to the battery.
lol... that picture just shows a wire...
You need to upgrade the wire from the alternator charging post to the positive post on the battery. It should go directly to the battery with an in-line fuse. If it is 0 awg wire then I suggest 300amp fuse rating. Good luck OP!
Pioneer Premier P880PRS ll Front Stage: US Acoustics 4060 - Random speakers currently ll Sub Stage: Crescendo BC3500D - 15" Xcon sealed @ 3.28 cubes ll Electrical: - Kinetik HC1800(front) NEW***DieHard P-2(rear)
beaker- I know this sounds like a lot of anime bullshit, but it is true.
He's not talking about the alt, he's talking about that fuse box... Look at the picture at the far right. That stud with the blue wire is the fuse box I believe he's talking about.
ahhh gotcha... I didn't do it that way as I did not want to cut into the fuse box with 0awg wiring... lol
i would do 0 gauge from alt + to battery +. then 0 gauge from battery + to fuse block +.
  • Who's Online   0 Members, 0 Anonymous, 853 Guests (See full list)
