Okay, well I've been planning my system for a while now, and I need some help with the mids and highs amps (and crossovers if necessary.) These are the amps I was looking at: 5000.5 and one of these two 1000.2 1000.4. My original plan was to use the 5000.5 with the 1000.2 and use this crossover. Then I would have the mids on the 2 channel amp, then 4 channels of the five channel amp would be for highs (regular and super tweeters.) The fifth channel would be for 10's that I plan to put in each door. Then I would run the amps at full frequency range since it has a crossover.
However I was told that if I could use only the filters on the amp and get rid of the crossover, it would increase sound quality. So my choice then was to put the mids on the 4 channels of the 5000.5 with the HPF at 150 Hz, then use a 1000.4 for the highs with the HPF at 2-3 kHz, and leave the 10's on the same channel of the 5000.5. The problem I have for this setup is that there is no LPF for the mids. That's really the only problem I see for this setup, but I don't know how I would fix that.
So, what do you guys think, should I go with the crossover; or go without it, and find a way to put a LPF on the mids?
Edited by LZTYBRN
These are the speakers I was looking at..May or may not help but here they are
10's (x4): http://www.parts-express.com/pe/showdetl.cfm?Partnumber=292-421 (might go with 8's instead)
mids (x16): http://www.parts-express.com/pe/showdetl.cfm?Partnumber=299-150 Not set on these, but really like them
tweeters (x8): http://www.parts-express.com/pe/showdetl.cfm?Partnumber=264-1028
super tweeters (x4): http://www.parts-express.com/pe/showdetl.cfm?Partnumber=264-348
